    Tue Jan 10, 2012 2:34 am
    Gloucester, Va
Quick question! Can you weld outside with regular mig wire and gas or is it to risky and only flux wire for outside?
Thank you for your time!
Everlast 250EX
Everlast I-Mig275 w/ Alum Spool Gun
Everlast Plasma60
Everlast 300 Water Cooler
You might be able to get away with it if you block the wind. Use card board. Plywood or even a sheet or tarp.
rahtreelimbs
    Mon Jun 14, 2010 10:39 pm
Just keep the wind out......you will be fine.
