    Sat Dec 11, 2010 8:30 pm
has any1 ever used the trailblazer302 with a spool gun welding aluminium pipe
sschefer
    Wed Aug 18, 2010 7:44 pm
6010 wrote:has any1 ever used the trailblazer302 with a spool gun welding aluminium pipe
Of course you'd want to check with Miller on this but just about any MIG machine can use a Miller Spool Gun if you also buy the SGA 100 (300.00) to go with it. Basically its a power source and a gas solenoid so the only other thing you need to do is to hook the power cable up. The work cable is the same.
Your 302 may have a direct connect option where you just connect the DIN plug to the machine and use the wire feed control and gas solenoid on the machine. That would save you from having to buy the SGA but if not, the SGA will get it done.
Most of the spool guns max out at 150a but if you go with a 3035 you can get it with the optional 200a barrel. I've got my Miller 212 setup that way and even though it has the plug n play connector I still use a SGA 100.
    Fri Feb 12, 2010 10:48 am
    YOUNGSTOWN, OHIO
What do you want to know about the 302 and the spoolgun. That is what I use for my mobile welding service truck. Excellent machine.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
6010
have u ever weld alumnium pipe with the 302 inth 6g position is it a up hand pass
    YOUNGSTOWN, OHIO
It is primarily an uphand weld. Have you ever welded aluminum pipe before? What is it exactly that you are welding? Which spoolgun are you using ? The 15A/30A
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
sschefer
jpence38 wrote:It is primarily an uphand weld. Have you ever welded aluminum pipe before? What is it exactly that you are welding? Which spoolgun are you using ? The 15A/30A
Here's Millers Guide: http://www.millerwelds.com/products/wir ... chart.html
Jim, he's posted this same question three times. In one thread he already has a spool gun and in another he's never done it before.. Humm, begining to sound a little odd to me.
    YOUNGSTOWN, OHIO
It does sound a little strange. He doesn't post anything other than a short question with really no info.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
