    Fri Nov 14, 2014 5:13 pm
I am still out of the country but my wife picked up a ford superduty front dana 60 that is waiting to be narrowed for the jeep
Sent from my SAMSUNG-SM-G890A using Tapatalk
Jeep Cummins transplant specialist
We are back on the jeep project after spending time on deployment. ImageImage
    Sun Sep 22, 2013 10:14 am
    Minneapolis Mn 55407
Jim FLinchbaugh wrote:I'll admit to being a little envious. I really want to put a 4BT in my Tahoe, but the $$ is prohibitive.
By the time I get the engine, trans adapter and trans controller I'd be way upside down
when one gets emotionally involved with a project,one becomes blind to the cost. Join the club,but you will get bragging rights. ;) ;)
A professional car restorer will tell that the dreamer will generally realize 20-40% of the cost + brag when he sells the ride.
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
Driver side motor mount progress ImageImage
Glad to have you back in one piece! Looks like you hit the ground running as soon as you opened the shop door.
BTW, The title of this topic has become a wee bit of an understatement. :lol:
I can rename it, if you would like a more appropriate title for what it's evolved into.
Steve
Otto Nobedder wrote:Glad to have you back in one piece! Looks like you hit the ground running as soon as you opened the shop door.
Steve
Thank! A new title is a good idea.
It's your topic, so let me know what you come up with. Or we could just add, "and then some..."
Steve
    Mon Feb 09, 2015 4:48 pm
    St. Johns, Michigan
Wow! Nice looking project you have going on there, you should have some nice low end grunt on tap. 1 ton up front should be about unbreakable. Are you going with a locker also?
Pete
Pete
We are test fitting the exhaust now that we have the alt and ac compressor installed ImageImage
Machined the crank sensor pulse pattern into the 4bt cummins harmonic balancer so the stock jeep tj tach will workImageImageImageImage
Making he221w rurbo parts :) :P ImageImageImageImageImage
Turbo clearance has been an issue but might have found a solution by turning the charger 90 degrees ImageImageImageImageImageImageImage
Test fit looks decent so far ImageImageImageImageImageImage
Started tinkering with the downpipe ImageImageImageImageImageImageImageImage
Oil supply and return mocked in place ImageImageImage
Got to spend a few minutes working on the next piece of the exhaust ImageImage
There isn’t much room for anything but engine under that hood.
I have been dragging my feet on this project but have made some good progress lately ImageImageImage
    Mon Nov 04, 2013 7:51 am
    The Netherlands
dzljon wrote: Image
Looks nice and clean!
Not sure if it's still a mock-up but I'd be a little concerned about the oil feed hose routing to the turbo in the picture..
Seems it's now running between the manifold and the downpipe. Could get awfully hot there even though it's a diesel and the peak exhaust temps are way lower than a gas one. PTFE (lined) hose can run up to 400F or so, but it will start degrading from that point onward. Also seems a little un-supported which could cause issues with the vibrations and weight of the hose cracking the fitting/connection to the turbo in the long run. (what? a big diesel having vibrations? nooooo.. of course not! :roll: )
Spraying hot oil over a turbo or manifold usually in the 'uh oh.. I think this is not so good' category :lol:
Could you perhaps run the oil hose from the block under and away from the manifold, towards the firewall and then up the firewall to get to the turbo from the other side? Just so it's far away from any 'hot pipes' as possible and with as little strain/stress on the hose and fittings?
Bye, Arno.
    St. Johns, Michigan
That little 4bt should be a beast in that TJ, interested in seeing what your fuel mileage improvement will be?
Pete
