    Fri Nov 14, 2014 5:13 pm
Rebuildable suspension heim's showed up
Sent from my SAMSUNG-SM-G890A using Tapatalk
Jeep Cummins transplant specialist
Rick_H
    Sat Feb 08, 2014 1:50 pm
    PA/MD
Is that the Evolution Machine heim? Very Nice!
My youngest helping with cutting the links
Lower link mock up
Lower link mock up progress
We are working on the suspension design
Started welding the driver side link
Jim FLinchbaugh
    Thu Sep 01, 2016 11:56 pm
    Kalispell Montana
I'll admit to being a little envious. I really want to put a 4BT in my Tahoe, but the $$ is prohibitive.
By the time I get the engine, trans adapter and trans controller I'd be way upside down
Thanks, I will have wait till April to get back to this project
I am still out of the country but my wife picked up a ford superduty front dana 60 that is waiting to be narrowed for the jeep
We are back on the jeep project after spending time on deployment. ImageImage
    Sun Sep 22, 2013 10:14 am
    Minneapolis Mn 55407
Jim FLinchbaugh wrote:I'll admit to being a little envious. I really want to put a 4BT in my Tahoe, but the $$ is prohibitive.
when one gets emotionally involved with a project,one becomes blind to the cost. Join the club,but you will get bragging rights. ;) ;)
A professional car restorer will tell that the dreamer will generally realize 20-40% of the cost + brag when he sells the ride.
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
Driver side motor mount progress ImageImage
Glad to have you back in one piece! Looks like you hit the ground running as soon as you opened the shop door.
BTW, The title of this topic has become a wee bit of an understatement. :lol:
I can rename it, if you would like a more appropriate title for what it's evolved into.
Steve
Otto Nobedder wrote:Glad to have you back in one piece! Looks like you hit the ground running as soon as you opened the shop door.
Steve
Thank! A new title is a good idea.
It's your topic, so let me know what you come up with. Or we could just add, "and then some..."
Steve
    Mon Feb 09, 2015 4:48 pm
    St. Johns, Michigan
Wow! Nice looking project you have going on there, you should have some nice low end grunt on tap. 1 ton up front should be about unbreakable. Are you going with a locker also?
Pete
Pete
We are test fitting the exhaust now that we have the alt and ac compressor installed ImageImage
Machined the crank sensor pulse pattern into the 4bt cummins harmonic balancer so the stock jeep tj tach will workImageImageImageImage
