don't make excuses about what tools you buy, buy the best you can afford
and maybe you will only have to do it once.
And you Sir, are the undisputed master of that artexnailpounder wrote: We are shop snoopers here..
And I think of it more like a sport than an art...lolAndersK wrote:And you Sir, are the undisputed master of that artexnailpounder wrote: We are shop snoopers here..
Last edited by exnailpounder on Mon Jan 23, 2017 11:57 am, edited 1 time in total.
- MosquitoMoto
You might not get a choice.LtBadd wrote:If Jeff shows up at your front door, don't let him inAndersK wrote:And you Sir, are the undisputed master of that artexnailpounder wrote: We are shop snoopers here..
"Are you finished with this door?"
Kym
Amen!!!motox wrote:don't make excuses about what tools you buy, buy the best you can afford
Have a look that the rouges gallery picture of Jeff. If Jeff turns up at your door, you are about to have a very good day or a very very bad one. (Hi Jeff, the cases of beer are on the way mate.)
He would be welcome at my houseLtBadd wrote:If Jeff shows up at your front door, don't let him inAndersK wrote:And you Sir, are the undisputed master of that artexnailpounder wrote: We are shop snoopers here..
(I don't have any tools in my house )
If my first project is an inspiration, by all means go aheadjrporter wrote:EtroniX - nice stand! I just joined the forum this morning, and the first thing I did was a search for bandsaw stands. You must have posted right after I did my search. I have a HF 4X6 that needs the stand replaced. I may not copy your design, as I already have casters and a bunch of angle I want to use, but thanks for the inspiration. Seeing your work might be the kick in the rear I need to get going.
I have a multipurpose machine (only used Mig so far) and am getting ready to try Tig for the first time - double inspiration!
Sent from my Commodore 64
A lot of practise and lots to learn...exnailpounder wrote:Somebodies been practicing aluminum welding. I see that big chunk of practice laying on the floor near your cycle lift. We are shop snoopers here...you've been warned
It looks like you are well on your way there my friend. You have some nice toys to play with.EtronX wrote:A lot of practise and lots to learn...exnailpounder wrote:Somebodies been practicing aluminum welding. I see that big chunk of practice laying on the floor near your cycle lift. We are shop snoopers here...you've been warned
Just a thought. Any solid fixtures that I have built ( work stands -stoves etc. ) with 4 legs I put 2 leveler screws on one side at the feet. With a solid structure no matter how accurate you build it the floor under is seldom perfect. That way if you move your saw around a quick turn of a bolt will fix any wobble. Also as was mentioned -wheels are a marvelous tool. All my movable fixtures have wheels and its easy to reconfigure the shop for whatever project your working on.
Thank you, exnailpounder I am having a lot of fun. Tried on some Stanley blades today. The one to the left is the first try. Second on the right.exnailpounder wrote:It looks like you are well on your way there my friend. You have some nice toys to play with.EtronX wrote:A lot of practise and lots to learn...exnailpounder wrote:Somebodies been practicing aluminum welding. I see that big chunk of practice laying on the floor near your cycle lift. We are shop snoopers here...you've been warned
I was thinking about putting some leveler screws in, but the material in the square tubing is pretty thin. I also thought about welding in some small nuts for adjustments, but also disregarded that due to the size of screw that would fit inside.homeboy wrote:Just a thought. Any solid fixtures that I have built ( work stands -stoves etc. ) with 4 legs I put 2 leveler screws on one side at the feet. With a solid structure no matter how accurate you build it the floor under is seldom perfect. That way if you move your saw around a quick turn of a bolt will fix any wobble. Also as was mentioned -wheels are a marvelous tool. All my movable fixtures have wheels and its easy to reconfigure the shop for whatever project your working on.
The band saw will have its own place in the garage. I don`t think I will be moving it around much. Maybe some wheels after a while. Time will show.
You must have some good eyes to weld that small...or a good cheater in your hood. For just getting your wings you're doing a fine job. One day you will look back and wonder what is so hard about it.
+2.5 on the noseexnailpounder wrote:You must have some good eyes to weld that small...or a good cheater in your hood. For just getting your wings you're doing a fine job. One day you will look back and wonder what is so hard about it.
Nice work for your first job, you built a mighty fine piece.
With your base now being open it would be a breeze to add a coolant system to your saw, your blades will last 2x as long or more.
A 115Vac sump pump, 5 gallon bucket, window screen, rubber hose, and galvi sheet metal to make a catch pan.
Thanks for the advise. I might do this. The parts I am cutting gets pretty warm.Rudy Ray wrote:Nice work for your first job, you built a mighty fine piece.
