So what do you do with a 1/2 or even 3/4 of a rod, if you put it back into the tube you won't be able to get it out??electrode wrote:Nope, the first part of the assembly was pvc cementing the lower cap in place.LtBadd wrote:Looks good, do the tubes pull out?
He sends them to me and I weld them back together and use'emLtBadd wrote:So what do you do with a 1/2 or even 3/4 of a rod, if you put it back into the tube you won't be able to get it out??electrode wrote:Nope, the first part of the assembly was pvc cementing the lower cap in place.LtBadd wrote:Looks good, do the tubes pull out?
Yes, getting old does suck...But here is what I do with the short pieces.
Never mind the rust on the welding table as I have yet to clean it up again, but I made a little ground clamp attachment (not pictured) that works pretty well but is a work in progress.
- Dscf2895r.jpg (60.31 KiB) Viewed 1823 times
I'm stealing your railroad spike third hand idea and claiming it as my own
Maybe cause he's a goddamned machinist posing as a welderRudy Ray wrote:Now why would a welder use wood to make anything?
Now why would a machinist use wood to build anything?exnailpounder wrote:Maybe cause he's a goddamned machinist posing as a welderRudy Ray wrote:Now why would a welder use wood to make anything?
Because he used to be a woodworker. Actually being a jack of all trades gives you many options. I bought my first TIG welder in June of 2008 and that is when I built the first filler holder (out of wood). I may have done it before the machine was delivered or shortly after. I built the second one to match the first one. I do powder coating too but I don't powder coat everything. And I built my own powder coat oven but not out of wood. I did build the spray booth out of wood though.Rudy Ray wrote:Now why would a machinist use wood to build anything?exnailpounder wrote:Maybe cause he's a goddamned machinist posing as a welderRudy Ray wrote:Now why would a welder use wood to make anything?
I use a .040 pure tungsten, myself. One end is pointed, the other ground flat like a screwdriver. Works great!electrode wrote:I knew that. So you use filler rod for tooth picks?Rudy Ray wrote:Just giving a hard time. As a welder, you should expect no less out of me.
I figured somebody was gonna say that... This guy used thoriated:Otto Nobedder wrote:I use a .040 pure tungsten, myself. One end is pointed, the other ground flat like a screwdriver. Works great!electrode wrote:I knew that. So you use filler rod for tooth picks?Rudy Ray wrote:Just giving a hard time. As a welder, you should expect no less out of me.
- jaws.jpg (25.62 KiB) Viewed 2207 times
That will work. Jody has a dual cap setup for different length rods from what I remember in one of his videos. You improved on it. I use all my stubbies asap when I can for little insignificant welds or tacks before I grab a new rod.
I could make a joke right here about you using your stubbie...but I won'telectrode wrote:That will work. Jody has a dual cap setup for different length rods from what I remember in one of his videos. You improved on it. I use all my stubbies asap when I can for little insignificant welds or tacks before I grab a new rod.
That's my other stubby. And I also use it asap when the occasion arises.exnailpounder wrote:I could make a joke right here about you using your stubbie...but I won'telectrode wrote:That will work. Jody has a dual cap setup for different length rods from what I remember in one of his videos. You improved on it. I use all my stubbies asap when I can for little insignificant welds or tacks before I grab a new rod.
Was that an intentional choice of words?electrode wrote:... when the occasion arises.
Brilliant. Well done, you!electrode wrote:Yes.Otto Nobedder wrote:Was that an intentional choice of words?electrode wrote:... when the occasion arises.
