It is currently Sat Feb 24, 2018 6:03 pm Advanced search
Cast iron tig braze - aluminum bronze
Re: Cast iron tig braze - aluminum bronze
Postby LtBadd » Sun Mar 19, 2017 10:35 pm
exnailpounder wrote:I would say as far as brazing characteristics, there was no difference...both "welded" the same but I used ALBr on this repair because of the strength advantage. I bought some ALBr on a whim when I was at the welders candy store and was itching to try it. I have used SilBr with great results and no problems but I can definitely see the merit in using ALBr for certain things. What did you use on that lathe shipswheels again?
per your recommendation it was SilBrz
Insert witty, sarcastic, or philosophical remark here.
LtBadd
Postby noddybrian » Mon Mar 20, 2017 5:38 am
Great job on both weld & finishing hope customer was impressed - quick question - why do you guys use aluminum bronze over " normal " nickel ? - I tried finding some here just to try but so far have not found any - I've always used nickel on cast where it can't be fusion welded with great results in terms of strength & machine ability - we do have bronze of that type in the UK but have only ever seen it in round bar & flat stock form - never welding rod.
Postby Granddaddy » Mon Mar 20, 2017 5:28 pm
Man, your to good for your own good !!! that looks awesome.
creek
Granddaddy
Postby Farmwelding » Mon Mar 20, 2017 5:41 pm
noddybrian wrote:Great job on both weld & finishing hope customer was impressed - quick question - why do you guys use aluminum bronze over " normal " nickel ? - I tried finding some here just to try but so far have not found any - I've always used nickel on cast where it can't be fusion welded with great results in terms of strength & machine ability - we do have bronze of that type in the UK but have only ever seen it in round bar & flat stock form - never welding rod.
If I remember correctly, a lot of times bronze is used because it doesn't have any cracking issues like nickel does. A lot of times it is a last resort if your nickel welds have failed and cracked.
Instagram: @farmwelding
Nick
Farmwelding
Postby MinnesotaDave » Mon Mar 20, 2017 8:10 pm
Thanks :D
Like normal, the customer said "that's looks great" and then really didn't look at it again.
I guess people who don't do metal work don't realize it's often difficult to do 8-)
I can't say why others use it, I did a little reading and it had good qualities while being easy to get - only about US-$15 per pound.
Nickel tig rod wasn't as easy to get so I just went with Al-Bronze-A2
Airco 300 - Syncro 350
MinnesotaDave
Postby MinnesotaDave » Mon Mar 20, 2017 8:11 pm
Granddaddy wrote:Man, your to good for your own good !!! that looks awesome.
creek
Thanks granddaddy - love your signature line :D
MinnesotaDave
Postby noddybrian » Tue Mar 21, 2017 4:03 am
It's a shame when people don't appreciate the effort & attention to detail involved in repairs such as yours - at least you get professional pride in a job well done - funny on the rods - over here nickel has been used for as long as I can remember & is easy to get & not too expensive - aluminum bronze is unheard of - last time I asked I got " that look " much like when I asked when 4943 might be available ! give it another 10 years or so people may have heard of it - we always seem a long way behind on welding related things.
Postby MinnesotaDave » Tue Mar 21, 2017 7:09 am
noddybrian wrote:It's a shame when people don't appreciate the effort & attention to detail involved in repairs such as yours - at least you get professional pride in a job well done - funny on the rods - over here nickel has been used for as long as I can remember & is easy to get & not too expensive - aluminum bronze is unheard of - last time I asked I got " that look " much like when I asked when 4943 might be available ! give it another 10 years or so people may have heard of it - we always seem a long way behind on welding related things.
I should be more specific - the stick welding rods, nickel 99 and 55, are easily found at the local hardware store.
They are common enough that they're sitting on the open shelf so a person can buy a handful by the pound like the other rods.
Some people have said that knocking off the flux makes them a tig rod - but I have no first-hand experience with that, so I decided against trying it for a customer project.
Alum.Bronze tig rod was listed to work so I figured that way was the safest route. :)
MinnesotaDave
Postby exnailpounder » Tue Mar 21, 2017 7:39 am
I got "that look" when I asked for 4943 at a new LWS about 2 weeks ago.. The wise guy salesman said there is no such thing and kind of smiled. There was another guy standing in line next to me who told the guy he was wrong and told me about another store about 3 miles away that had it so I walked out and went to the other store and got it. 8-) Gosh that felt good.
Postby MinnesotaDave » Tue Mar 21, 2017 9:31 am
I hear you - I had to explain 4943 to the guys at my local store too.
They are pretty nice to me though and assumed I might know what I was saying :)
MinnesotaDave
PreviousNext
Return to Welding Projects - Welding project Ideas - Welding project plans
