Tube bender
Posted: Mon Mar 20, 2017 6:12 pm
by Mihtu
More pics
Re: Tube bender
Posted: Mon Mar 20, 2017 6:57 pm
- snip_20170320184338.jpg (13.9 KiB) Viewed 2398 times
- snip_20170320184458.jpg (23.85 KiB) Viewed 2398 times
If your using windows, before you upload you can rotate easily by "right clicking" on the pic and select either rotate clockwise or counterclockwise
- snip_20170320185417.jpg (7.58 KiB) Viewed 2398 times
Be sure your cursor in where you want the pic to go BEFORE you select "Place inline"
Hope that's clear
Re: Tube bender
Posted: Tue Mar 21, 2017 7:50 am
by Mihtu
If you want dimensions,I can come up with something,probly wouldn't be all that difficult to make you a drawing,I actually built it fron the picture I saw,then cut and welded what seemed to make sense,the guy who originally built one,tried to post instructions,but they threw me off a bit,kinda not in order,so I figured what have I got to lose,$3 in scrap and some practice,just so happens it actually worked!
Re: Tube bender
Posted: Wed Mar 22, 2017 2:41 pm
by PhillerTime
Looks like it works great!
Sent from my Nexus 6 using Tapatalk
Re: Tube bender
Posted: Wed Mar 29, 2017 3:36 pm
by Granddaddy
I would love some dimensions, that looks like a natural winner !!!!
creek
Re: Tube bender
Posted: Wed Mar 29, 2017 10:20 pm
by Mihtu
Base for bench is 2 inch angle,you need an 8",and a 16" piece, the upright for axle are 8" also,the mandrel is a piece 24" long bent around a b-tank.then 2 pieces 6" long,I bent and welded the loop,then added in the 6" pieces, how I positioned them is put a level on the top flat,then added the 2 in the perfect verticle position,found the center ,drilled a half inch hole,for the axle bolt,which I welded to the 2 6" pieces,the rib on the back is a little too big,but it's what I had,1/8" solid rod,the cleat is 2 7" pieces with a roller,and another on top to hold the tubing when you pull it through!
Re: Tube bender
Posted: Wed Mar 29, 2017 10:59 pm
by Mihtu
Bender pictures
Re: Tube bender
Posted: Mon Apr 03, 2017 10:40 am
by Granddaddy
Thanks M !!
