base:
2" hr angle
1 1/4" sq hr tube
1/8" sheet steel base
drawers:
22 ga steel
1/8" alum diamond palte
Top:
1" alum sq tube
1/8 alum sheet.
sides:
alum sheet
5" casters
- j-table clecos.JPG (92.38 KiB) Viewed 1756 times
- j table base edge.JPG (68.75 KiB) Viewed 1756 times
- IMG_3665.JPG (94.1 KiB) Viewed 1756 times
- IMG_3708.JPG (81.19 KiB) Viewed 1756 times
- j-table smooth top.JPG (77.54 KiB) Viewed 1756 times
- IMG_3674 2.JPG (70.33 KiB) Viewed 1756 times
- j-table frame alum.JPG (99.76 KiB) Viewed 1756 times
- table hinge brackets.JPG (97.04 KiB) Viewed 1756 times
- table draw corner.JPG (63.31 KiB) Viewed 1756 times
- table draw folded.JPG (78.4 KiB) Viewed 1756 times
- table draw layout.JPG (112.78 KiB) Viewed 1756 times
- j table drawer front.JPG (98.88 KiB) Viewed 1756 times
- IMG_3721 2.JPG (114.15 KiB) Viewed 1756 times
- IMG_3775.JPG (58.21 KiB) Viewed 1756 times
- j table finished.JPG (82.58 KiB) Viewed 1756 times
You really took cart building to another level there Craig. Very nice design and top notch craftmanship.
Like the Logan lathe too. I see you're also one of those fellers that like their tig wire all nice and neat and protected..
jeff
had them on a cart but then i hijacked Jody's mount to wall idea.
already had the tubes build just needed to make the clips
for the wall mount. neat and out of the way now.
I'm afraid I have been shamed into making some tubes....damn you guysmotox wrote:jeff
If you do this you run the risk of seeming to be organized...exnailpounder wrote:I'm afraid I have been shamed into making some tubes....damn you guysmotox wrote:jeff
