Die electric flange kits for bolting up flanges use a plastic sleeve that looks like a big straw ( about the same material and thickness) to go around the bolts. And then fiber washers that look like circuit board material. About 1/8 thick.
That would certainly save some time. I'm gonna check McMaster-Carr this morning.Poland308 wrote:Die electric flange kits for bolting up flanges use a plastic sleeve that looks like a big straw ( about the same material and thickness) to go around the bolts. And then fiber washers that look like circuit board material. About 1/8 thick.
I am using something like these with my build...
http://www.ebay.com/itm/6-Glastic-2015- ... Swol5Y3Dne
I Used a set of rubber mounts like that for a pedestal grinder that I built it makes it kind of hard to tension the belt because it begins to sideload the rubber grommets.
All you have to do is isolate your motor. My set up is different.LtBadd wrote:Sounds like you may already have an answer, I haven't gotten that far.exnailpounder wrote:I was thinking about some Delrin sleeves and thrust washers..would Delrin be a good choice? I know it's very machinable.motox wrote:jeff
you have a lath, fab up some nylon bungs to separate metal from bolts.
Question, may be stupid, even with a metal frame if the ground strap remains on the shaft, wouldn't the current take the most direct path (of least resistance)?
- 20170501_123827.jpg (52.97 KiB) Viewed 1114 times
- 20170501_125329.jpg (56.14 KiB) Viewed 1114 times
