It is currently Sun Feb 18, 2018 5:05 am Advanced search
tig wheel guide
tig wheel guide
Postby crimas » Mon Jul 10, 2017 9:17 pm
hi guys, i make this simple wheel guide looked on the torch cup for make easy and precise tack and welding on thin pipe, work very good on welding without filler rood such as 0,8mm steel (in picture) with 0,4mm gap between electrode and piece
crimas
Re: tig wheel guide
Postby clavius » Sat Jul 29, 2017 11:20 am
Now that's an interesting gadget. Sort of like a mini version of a cutting torch rolling guide. Have you used it much? does it help?
clavius
Re: tig wheel guide
Postby crimas » Mon Jul 31, 2017 5:00 pm
it help when you make 50 or 100 tack at day on very thin metal were the distance between the electrode​ and the metal are very important for make the tack and not burn the two pieces, with this you make the same tack every time like the first
Inviato dal mio U FEEL utilizzando Tapatalk
crimas
Re: tig wheel guide
Postby Gene.243 » Tue Aug 01, 2017 4:15 am
That's a good idea!
Gene.243
Re: tig wheel guide
Postby Simclardy » Sun Aug 06, 2017 8:03 am
Nice job!
Sent from my SCH-I535PP using Tapatalk
Simclardy
Return to Welding Projects - Welding project Ideas - Welding project plans
