It is currently Fri Feb 23, 2018 2:16 pm Advanced search
My fire pit..
My fire pit..
Postby OzFlo » Thu Jul 13, 2017 9:01 am
Hey all,
I haven't been that active of late but I have been around keeping an eye on things.
I have been wanting to build a fire pit/brazier for quite some time so I bit the bullet and made a start.
I used 3mm thick mild steel sheet for the body of the pit and 30mm x 2.0mm square tube for the base as well as re-purposing my daughter's old bed frame rails for the top of the base. I used my Everlast MTS251si to do both Mig and Tig welds, using Mig to do the lions share of the welding. I tig welded the base of the frame. I used .030" (0.8mm) solid wire and what is known as Argoshield light shielding gas here in Oz.
The welds are not that great (praise the Lord for grinders!) and the thing is probably not that square because I cut everything by hand and I only have a small stronghand nomad welding table, but it is a fire pit and I made it myself :D
This project has made me realise that I need to do a whole lot more practice!!!
I still need to cut in some breather holes for better airflow.
Image20170708_225505
Image20170702_172730
Image20170713_190254
Image20170713_190315
Image20170713_195417
OzFlo
Re: My fire pit..
Postby motox » Fri Jul 14, 2017 6:49 am
looks like a working fire pit to me!
I'm sure the burning wood doesn't care
if its square and level..
nice build
motox
Re: My fire pit..
Postby OzFlo » Fri Jul 14, 2017 7:42 am
motox wrote:looks like a working fire pit to me!
nice build
Thanks Craig :D
OzFlo
Re: My fire pit..
Postby OzFlo » Mon Jul 17, 2017 9:02 am
I decided that the fire pit needed a cover to keep the rain out so I went ahead and made one.. I used the same 3mm sheet stock as the fire pit itself as well as 32x3mm flat stock for the edges. I fashioned the handles out of the the flat stock and welded them on.. All that remains is to paint it.
Image20170716_143602
Image20170716_143544
Flo
OzFlo
Re: My fire pit..
Postby clavius » Mon Jul 17, 2017 12:12 pm
OzFlo wrote:
.... but it is a fire pit and I made it myself :D
This is the key thing right here. Very nice! The welds are obviously perfectly functional, and you are the only person who will be sitting around that thing silently critiquing the welds. Everyone else will be just enjoying the fire. Nice job.
clavius
Re: My fire pit..
Postby OzFlo » Wed Jul 19, 2017 3:35 am
Thanks clavius :D
OzFlo
Re: My fire pit..
Postby deni822 » Wed Jul 19, 2017 11:18 am
Looks awesome.
deni822
Re: My fire pit..
Postby richard parker » Wed Jul 19, 2017 4:26 pm
nice build man, i think i want to have a go!
richard parker
Re: My fire pit..
Postby OzFlo » Thu Jul 20, 2017 12:48 am
deni822 wrote:Looks awesome.
Thanks mate :D
OzFlo
Re: My fire pit..
Postby OzFlo » Thu Jul 20, 2017 12:53 am
richard parker wrote:nice build man, i think i want to have a go!
Thanks Richard. You should! There's a million reasons to put it off and not have a go but the satisfaction of having built something yourself (even if it's not 100% perfect) definitely makes it worthwhile! A good project is great for clearing the head too! :D
OzFlo
Next
Return to Welding Projects - Welding project Ideas - Welding project plans
