Should be the c6 trans. Pretty durable. Could upgrade to a newer auto. Or a 5 speed if you feel like rowing gears.
For i.p. and injectors, look into Conestoga diesel, r&d IDI performance, and there's a guy that goes by typ4 on some forums. Those 3 do better parts than you will get at the parts store.
Sent from my SM-G892A using Tapatalk
Not sure how practical a newer auto would be as they will likely require a stand alone computer due to the 7.3 being mechanical injection - if it has a C6 in good shape I'd keep it - just change filter / fluid & maybe add a bigger cooler - I like the boom idea but the weight is adding up & will only increase as the amount of spares / tools accumulates ! I figure a 1ton is going to be on or past it's limits - that's why many service trucks start out with a heavier truck to allow for " upgrades " !
Correct. But they also ran the e40d behind the IDI. Which ran it's own computer.noddybrian wrote:Not sure how practical a newer auto would be as they will likely require a stand alone computer due to the 7.3 being mechanical injection - if it has a C6 in good shape I'd keep it - just change filter / fluid & maybe add a bigger cooler - I like the boom idea but the weight is adding up & will only increase as the amount of spares / tools accumulates ! I figure a 1ton is going to be on or past it's limits - that's why many service trucks start out with a heavier truck to allow for " upgrades " !
But those standalone trans computers sure are nice. Offer way more tuning/control than stock. Lol
Wouldn't be a big ROI though, so I would understand leaving it be.
Right - I forgot they used the e4od behind the 7.3 - slightly surprised as it's not got a good reputation here with heavy use but I'm basing that on very limited experience as in the UK there are very few full size trucks around & of those Ford is the least popular - I ran one for a while but can't afford the fuel now - that was dead reliable - 460 with a C6 in front of NP205 & Dana 60's - towed all sorts with it - good truck - I doubt the OP will want to change much as it's simple & reliable now - what I've found is the more you change a truck from standard the bigger & more expensive the headaches get when it's broke ! I wish I'd figured " KISS " years ago - also jumping trucks & playing with them in the sea is bad but when your young it has to be done !
Popeye the old miner
- Popeye the old miner
Thank you, it took about 7 weeks to build, I built it last summer, needed to take some time off work for some other issues, stayed off til i got it done,its a long story.ollie81 wrote:thats an awesome truck! I bet it took a good while to put together? How long have you spent on it?
Popeye, next time I'm in your neck of the woods (only God knows when that might be), we're going to have to cook something with that weed-burner, and throw back a beer or three.
Steve
Steve
Sounds like a great idea, there is quite a few deer around around here that need to be ate, and some snappin turtles and even a 450 pound bear we saw a few weeks ago out on a job we were workin on...only 30 feet away...big ol thing and very handsome...for a bearOtto Nobedder wrote:Popeye, next time I'm in your neck of the woods (only God knows when that might be), we're going to have to cook something with that weed-burner, and throw back a beer or three.
Steve
