It is currently Tue Jan 23, 2018 9:17 pm Advanced search
Fab table
Fab table
Postby Splice_Welding » Sat Dec 09, 2017 4:42 pm
5x10 fabrication table I made for my small shop that I figured I'd share. Each bar is independently adjustable front to back and left to right (or fore & aft, and port & starboard if you live near the water) in order to create a dead flat surface. Clamp anywhere in the field, and can use the spaces in between to cut sheet goods (I primarily use a circ saw). If any of the bars get dicked up, they are easily replaceable. I ended up using a lower standard height of 29". The hardware assembly is time consuming, but it's worth it once they're all locked in.
https://imgur.com/a/LMymf
Splice_Welding
Re: Fab table
Postby Metric » Sun Dec 10, 2017 12:45 am
Very nice. I like the modular design of the thing so you and adjust on the fly and replace bits when needed. For the hight adjustment you mentioned for the cross beams is this done through a Allan Key head bolt and there is a nut on the bottom which you just raise and lower to adjust the hight?
Metric
Re: Fab table
Postby tungstendipper » Sun Dec 10, 2017 7:50 am
Where's your dog? Saw the dog bed, but no dog.
BTW... Great looking table. I like the flex conduit on your electrical box. That will keep the hot slag out!
I will be interested in how often you will have to adjust your table for flatness?
Everlast 210 EXT
3 old socks
tungstendipper
Re: Fab table
Postby Splice_Welding » Sun Dec 10, 2017 12:57 pm
Metric wrote:Very nice. I like the modular design of the thing so you and adjust on the fly and replace bits when needed. For the hight adjustment you mentioned for the cross beams is this done through a Allan Key head bolt and there is a nut on the bottom which you just raise and lower to adjust the hight?
Yes, that is exactly how I do it.
Splice_Welding
Re: Fab table
Postby Splice_Welding » Sun Dec 10, 2017 1:05 pm
tungstendipper wrote:Where's your dog? Saw the dog bed, but no dog.
Thanks. This is the second one of these I’ve built. The first one I built over 3 years ago and has never needed adjustment. Still dead flat. I did use thread lock though. The first one worked out so well I built this one for this new/bigger shop.
Splice_Welding
Return to Welding Projects - Welding project Ideas - Welding project plans
