Re: Small welding table...
Posted: Mon Feb 05, 2018 7:42 am
Ok, I should update this thread.
My LWS gave me some Harris Super MissleWeld...I used it to weld Chrome nuts to mild steel angle iron.
That got me the casters, then looking at it I decided to put a cross member from the front to back. I intentionally left the sides open, that way I could put my welder under the table if I wanted. I may do that for the interim. But the problem is the argon tank won't fit under there, and I want the argon together with the cart, that's the way it was meant to be.
I still need a torch holder, haven't decided what to do...was going to just use pipe, but the stubby kit doesn't seem well suited for that...the pipe I have is also pretty heavy. I think I may do something with a magnetic base. I have an idea to use an S hook I forged, cut it in half and use the two loops spaced to hold the torch. Mag base would probably be best in case I want to move it.
Alan
Alan
