Untreated nuts
Posted: Tue Apr 24, 2018 10:15 am
by Homemade
I’m looking for some nuts to weld to adjustable table legs. Do you know if fastenal... or any of the fastener supplier sells nuts without the zinc coating?
This is for a run of 100pcs. I wouldn’t bother with it for just 4 legs.
Re: Untreated nuts
Posted: Tue Apr 24, 2018 10:29 am
by Farmwelding
Considered stainless steel nuts?
Re: Untreated nuts
Posted: Tue Apr 24, 2018 11:11 am
They are available, don't have a source, but I do have a customer that provides them with a part I do, and it makes welding so much easier
Re: Untreated nuts
Posted: Tue Apr 24, 2018 1:52 pm
Fastensal, stainless as suggested. Be careful to not have a stainless bolt in the nut when welding else it will fuse permanently due to the heat. Use some thread release and a black oxide if you need to align the nut exactly.
Re: Untreated nuts
Posted: Tue Apr 24, 2018 1:59 pm
My customer gets them from Fastenal, as CJ wrote, be careful if you go the stainless route, I'm sure the sst is going to be $$$
Re: Untreated nuts
Posted: Tue Apr 24, 2018 2:13 pm
by smithdoor
Homemade wrote:I’m looking for some nuts to weld to adjustable table legs. Do you know if fastenal... or any of the fastener supplier sells nuts without the zinc coating?
Yes
Try grade 5 or 8 typically they come black
I just weld with or without plating
Just do welding out side
Dave
Sent from my SAMSUNG-SM-J320A using Tapatalk
Re: Untreated nuts
Posted: Tue Apr 24, 2018 2:57 pm
by Franz©
Square steel nuts - not plated. Gives you maximum meat to weld to at the corners. Most suppliers have wo9odewn kegs of them stashed next to the kegs of iron rivets.
If you use hex nuts run a threaded carbon rod into the nut for thread protection. Knich the carbon out when finished welding and you're usually good to go.
Re: Untreated nuts
Posted: Tue Apr 24, 2018 5:06 pm
by AndersK
Search for DIN 929 weld nut.
Here's a vendor in Ohio
http://www.branamfastening.com/product- ... oCXF7w_wcB
Uncoated and has a small guide making them self centering. Bolt in last pic is just for keeping the clamp away.
- IMG_20180424_58846.jpg (14.88 KiB) Viewed 2382 times
- IMG_20170226_36343~2.jpg (55.01 KiB) Viewed 2382 times
Re: Untreated nuts
Posted: Tue Apr 24, 2018 5:17 pm
by Homemade
I don’t have a picture. The leg is made of 1.5” square stock. The adjustable foot is 3/4” lead screw. I need to weld the top of the lead screw, but the nut has to be small enough to pass three the lead screw nut. This way I can completely remove the adjustable foot and get the square tube leg powder coated. I’m thinking a 1/2” nut will fit threw. I have to do some sizing.
Re: Untreated nuts
Posted: Wed Apr 25, 2018 2:26 am
by Arno
Weld-nuts are specifically made for this purpose:
https://www.fastenal.com/products/faste ... Nuts%22%7C~
Some have extra tabs or feet to make welding them easier.
Bye, Arno.
Re: Untreated nuts
Posted: Wed Apr 25, 2018 5:43 am
by Antorcha
Call them. You know. Like on a telefono tingie. Load up. They have EVERYTHING
https://www.albanycountyfasteners.com
Re: Untreated nuts
Posted: Wed Apr 25, 2018 10:24 am
by ljdm1956
Yeah, it might be childish, but seeing the title of this thread "Untreated Nuts", my advice would be see a doctor?
