nov0798
    Sun Apr 14, 2019 4:54 pm
    Dumfries, VA
I am in the process of mounting a Billy Goat Force 13 blower to the front of an ATV/Gator. One of the things that I must make sure of is that the machine can pivot to follow the ups and down on the trail surface.
I was thinking of a vertical frame that mounts to the ATV/Gator, then pivot that at the top. from there run a second vertical frame back towards the ground, where it will pivot to a horizontal frame. The blower would mount on the horizontal frame, and at the end of that, there would be a wheel. The thought is that the frame would articulate and allow movement as the ATV/Gator went up and downhill.
Does anyone know if this will work, or have any other ideas?
Thanks
Brian
