You guys are being silly now. You know very well the OP means weld not welder testing.
He probably means some kind of combined mechanical and sonic tester like this:
You hit the weld and if it doesn't fall off it passes the mechanical test. At the same time if it sends out a clear note, it passes the sonic test. If the sound is dull that means there are inclusions and you have to grind it out.
- Weld tester.png (51.37 KiB) Viewed 2246 times
U probably right.Coldman wrote:You guys are being silly now. You know very well the OP means weld not welder testing.
Weld tester.pngYou hit the weld and if it doesn't fall off it passes the mechanical test. At the same time if it sends out a clear note, it passes the sonic test. If the sound is dull that means there are inclusions and you have to grind it out.
Where can i buy one! Does it work on other things? Like my car?
It was developed and available, l believe, in California where other methods of inspection are known to be carcenogenic.
Be aware that ever since Nick Fury put his eye out weld testing on the flying carrier, it's mandatory you wear non carcenogenic safety glasses.
Here's some info from AWS D1.1 and a simplistic example of one.
- guided bend test jig1.JPG (65.19 KiB) Viewed 2159 times
- guided bend test jig2.JPG (33.3 KiB) Viewed 2159 times
- guided bend test jig3.JPG (34.99 KiB) Viewed 2159 times
- Coupon bender guided bend test.jpg (38.73 KiB) Viewed 2159 times
