Omid20110
    Sat Jul 18, 2020 12:46 am
Hello all,
Nowadays Flash-butt welding machine is used in rail industry to weld a Hadfield crossing with a R260 rail, but I want to know if there is any welding technique to use instead of Flash-butt welding.
Thanks in advance
There are always other ways to weld metals together. Sometimes the chosen method is used because of the end results, IE maybe it reduces the haz, thereby making the resulting weld more flexible or less prone to stress cracking. Or it might be the cheapest or fastest way to get an acceptable weld.
tweake
    Mon Dec 18, 2017 4:53 am
    New Zealand
i had to google that, its quite interesting method.
of course most people know thermite welding for rail. however it seams thats a low quality weld and flash butt weld is much higher quality.
Omid20110
Yes actually flash-butt has higher quality than other types of welding. But the flash-butt machine is expeniseve and I'd like to find an alternative way instead of using it.
