Bls repair
- Bls repair
Bls repair
- Bls repair
Cleaning up the breaks
- 0661EBAA-B756-42E5-827F-B5129E75EB99.jpeg (55.35 KiB) Viewed 1974 times
- 7ACBE555-6257-42D5-A1D9-B3A8C1FBD2F7.jpeg (55.35 KiB) Viewed 1974 times
Bls repair
- Bls repair
Here’s the problem
- 0903AB1D-7809-4DB2-9FD2-FE7667233978.jpeg (58.28 KiB) Viewed 1973 times
Bls repair
- Bls repair
More problems.
- 1445EA15-D581-4D9A-9737-DAE1B1576AD1.jpeg (54.45 KiB) Viewed 1972 times
- F510A4D4-4406-4B02-BD90-48CC98A73543.jpeg (53.2 KiB) Viewed 1972 times
Might adjust my opinion a bit. That weld split in the center. Says to me that the weld had a stress point, hole or crack, at the beginning of the bead. That led to a stress point. Bad weld would have torn away from one side or the other if it was cold. Posible that the weld was undersized but that comes down to a design or Qa issues. Split in the middle says the weld held to its max capacity to both sides but couldn’t deal with max forces.JayWal wrote:Thats a nice example of a good looking mig weld that is actually garbage.
Bls repair
- Bls repair
There’s a metal plate that runs between the two welds
- 8DE87EAB-CEE7-45A9-98CA-059D1F6F4339.jpeg (56.61 KiB) Viewed 1907 times
Looks to me like a 3 pass weld, and it split right along where 1 pass is laid onto the previous one. But it gets a little blurry when you zoom in that far. You might be rightPoland308 wrote:Might adjust my opinion a bit. That weld split in the center. Says to me that the weld had a stress point, hole or crack, at the beginning of the bead. That led to a stress point. Bad weld would have torn away from one side or the other if it was cold. Posible that the weld was undersized but that comes down to a design or Qa issues. Split in the middle says the weld held to its max capacity to both sides but couldn’t deal with max forces.JayWal wrote:Thats a nice example of a good looking mig weld that is actually garbage.
I do believe that the issue here is people using a mig but not keeping the proper travel speed. It's easy to go slow and think you are putting in a big weld, but really you are just putting in caulk. If you go fast enough to keep the wire chewing into the base metal, she ain't going anywhere. But it may require multiple runs.
Long story short, mig is easy to get wrong. No safety net, as jody says.
Bls repair
- Bls repair
Yep kinda what I was trying to say. I got nothing against mig, but it is possible to get a weld that looks good, but has zero penetration.weldin mike 27 wrote:I do believe that the issue here is people using a mig but not keeping the proper travel speed. It's easy to go slow and think you are putting in a big weld, but really you are just putting in caulk. If you go fast enough to keep the wire chewing into the base metal, she ain't going anywhere. But it may require multiple runs.
I agree. I have a Mig machine but it’s my las option I chose. Don’t get me wrong it has it’s place but like said it’s easier to mess up than to get right. Good enough isn’t always right.
