I'm making a mailbox out of one of those party helium tanks. It's coming along fine, but I cannot figure out a hinge for the door. The big box hinges that are narrow enough have quite a bit of slop in them and are the sturdiest designs when only one is used.
I was wondering if anyone has a design or know of a vendor that might have something that is fairly rigid laterally and narrow. Ideally it would mount on the inside but if exterior is the only way - so be it. Mostly if it can survive a mailman having a bad day, I'd be happy lol.
Thanks for looking.
A couple hinges like this might work:
https://www.mcmaster.com/1995A1/
You might need to make some blocks with tapped holes to mount them inside if you're trying to hide the hardware.
- dudley
- hinge.JPG (27.22 KiB) Viewed 1997 times
- dudley
I've used roller chain in a bind before. Bout as narrow a hinge you can get. Like heavy bike chain? 60 chain would be 3/4" ish wide, or a sturdier 100 chain is around 1"
Something like this pic I googled, but they used double chain.
This looks like a great way to make a hinge for a tight spot.. smartJayWal wrote:I've used roller chain in a bind before. Bout as narrow a hinge you can get. Like heavy bike chain? 60 chain would be 3/4" ish wide, or a sturdier 100 chain is around 1"
https://www.hingeoutlet.com/
I’ve had good luck with these guys.
Would something like this work?
- Screenshot_20201119-054555_Chrome.jpg (34.08 KiB) Viewed 1918 times
