nick121
    Sun Feb 23, 2020 10:33 am
Heres a cart I just built for my new aspect 230 tig. I have a old miller water cooler im planning on putting underneath and addimg a watercooled torch.
Im happy with how this turned out and just used material I had on hand
Looks good, "run whatcha brung" as we used to say at the drag strip! Meaning you gotta use whatever ya got on hand. :)
Good job Nick!
    Sat Feb 17, 2018 10:10 pm
    Carberry, Manitoba, Canada
Looks good!
Jakedaawg
    Mon Feb 16, 2015 8:45 pm
    Near Traverse City, Mi.
Have you ever used a dynasty? Could you post a review of your aspect? Disregard if its not an ac/dc tig machine. I've had my dynasty for 4 years and its getting a ton of hours on it. I'm thinking of picking up another but I want to consider the comparable Lincoln model.
nick121
Jakedaawg wrote:Have you ever used a dynasty? Could you post a review of your aspect? Disregard if its not an ac/dc tig machine. I've had my dynasty for 4 years and its getting a ton of hours on it. I'm thinking of picking up another but I want to consider the comparable Lincoln model.
So i'm still pretty green with tig, so can't really give a full review since I'm still working on running consistent beads. But I did do quite a bit of research before jumping in, previous to this I put maybe a couple hrs on a syncrowave 351.
I originally was planning on a square wave 200 but decided to wait longer till I could afford this aspect. Mostly in a buy once cry once mindset.
I looked into the dynasty line and in my opinion the aspect has as much as the dynasty and at a cheaper price. From what I was reading, the dynasty you have to purchase a "expansion memory card" to get the EN EP independent waveform setting.. it comes on the Lincoln no need to buy it for extra.
I was comparing to the 210 dynasty, and the extra 20 amps on the aspect doesn't hurt on aluminum either. For me I'm glad I went with the aspect.
Keep in mind, if you are looking at the 375 aspect, it only puts out 250 amps on single phase.
Olecoot
    Thu Nov 26, 2020 10:01 pm
    Somerset, Texas
Nice cart :)
Fame is vapor, popularity an accident, riches take wings. Only one thing endures and that is Character.
nick121
Oscar wrote:Looks good, "run whatcha brung" as we used to say at the drag strip! Meaning you gotta use whatever ya got on hand. :)
Yup, and i'm pretty happy with how it turned out. I see you have quite the line up of welders! I had strongly considered the 221 invertig but ended up with the aspect mostly cause I wanted something I could go buy in a weld shop. (i'm in canada)
How do you like the inverarc200?
