Had to build a cover for the connection ports on a CO2 trailer.
Like putting lipstick on a pig...
Steve
delraydella
    Mon Apr 25, 2011 7:35 pm
    Detroit, MI
Nice! Is that a hydraulic pusher arm i see in the bottom picture on the right?
No lift arms... This client's drivers are slighly above broccoli in intelligence. That's a simple locking arm, that latches automatically, and has to be released manually, kinda like a cheap tool-box lid.
It had to be as idiot-proof as possible, and they weren't going to pay for gas struts.
If they'd break down and buy a half-decent manual box-brake... I could have done this in half the time and gotten something I wouldn't mind putting glossy paint on. It's not bad at all, but it could be better if they'd spend some money now and then.
Steve
delraydella
    Detroit, MI
...slightly above broccoli in intelligence....hmmmmm......they must be Teamsters :lol:
I was leaning toward "illegals", but "teamsters" will do. :D
The hold-open is scratch-built entirely from 1 X 1/8" SS angle, with a 5/16 SS bolt & nylock. It lands on the right tail/brakelight assembly's forward bolt, replaced with a 2 1/2" bolt.
Steve
delraydella
    Detroit, MI
So it's just a pressure fit and you lift the door up a little to release it?
It's a gravity drop. The angle keys onto the bolt when the door is opened. it is released manually by pulling on the tab at the bottom.
Steve
