The air-ride supplier, in response to our customer's complaints, tried to put the onus on us, claiming we were doing improper installation. I developed a process and a set of documents to prove that every aspect of our installations were within 1/16", meeting (and in most cases greatly exceeding) the manufacturer's specifications. Two years of documenting this thoroughly, and our customer has dropped one major vendor, and selected another. We are now installing the new vendor's product to the old specification, partly because the process is established and easy, partly because it exceeds the manufacturer's requirements.
I guess this is a digression, and the point I was trying to make is that there's a LOT that goes in to building a trailer and it's suspension, making it more economical (and safer from a liability standpoint) to go down the road and buy one, than it is to build one from guesswork.
No doubt that it's cheaper to buy than build in a lot of cases but unless it's ''OVERBUILT" it is suspect. If I had back all the money I have pissed away on pet projects, I would be retired and laughing at all you guys that think welding is importantDLewis0289 wrote:I thought I was bad! LOL Kind of made me yaw-n (get it "yaw") I really entertain myself.Otto Nobedder wrote:Well, Roger,
At least if your axles were not aligned to the hitch and to each other, the trailer would turn that "learning curve" easily! (I work on heavy OTR trailers, including complete suspension replacements with air ride, so I get everything you just said.)
I am probably the most guilty of doing "projects" because I can. If you want to do it for the satisfaction of building it yourself go for it, a couple mistakes, that is how you learn for the next one. I buy over a 1000 tons of steel a year, so I get good pricing. But at the end of the day figuring up all my time it is just cheaper to go down the road to the trailer manufacture and buy it.
- DLewis0289
I am the king of money pissing.....a toy that shoots back at you while you are trying to shoot it.
- IMG_2368.JPG (57.21 KiB) Viewed 1128 times
- IMG_2362.JPG (70.49 KiB) Viewed 1128 times
- IMG_2364.JPG (37.29 KiB) Viewed 1128 times
- ldbtx
I would dearly love to know more about that device. Such as, what are you shooting it with, and what is it shooting back at you? Looks like fun, if it's not lethal.DLewis0289 wrote:I am the king of money pissing.....a toy that shoots back at you while you are trying to shoot it.
Larry
Miller Bobcat 225
Tweco Fabricator 211i
AHP AlphaTIG 200x
Lincoln SP-135+
Hypertherm Powermax 30 Air
ProStar O/A torch
AHP AlphaTIG 200x
Lincoln SP-135+
ProStar O/A torch
- DLewis0289
Ok here I go lol. Years ago I had a very different life than skilled trades. And taking a page out of the Taser handbook, it is "Less than lethal".
It is remotely operated up to 300 meters away and the ordnance is basically a battery of fireworks missiles. The old saying is...."If you have perfect sight picture, perfect sight alignment and are in a perfect isosceles stance, you are not in a real gun fight"
Like Simmunition training this introduces stress (stress innoculation as it pertains to the sympathetic nervous system/fight or flight), however Simmunition is very expensive with the outfitted Glock's and PPE. This is basically safety glasses and any pistol with any ammo within reason. .380 through 9mm all the way to 45ACP.
The contests we have are done from 7yds/21 ft and the object to win is to disable (knock down two paddles)the threat with the least amount of rounds in the shortest amount of time, the whole time this thing is spitting missiles with realistic report/smoke/ and it will hit you lol. Caught one in the knuckle one time and it does sting a little.
It is also fun to camouflage it in the woods and send guys in with the RO watching from a safe distance and deploy in an ambush scenario.
- ldbtx
That does look like fun. I just may have to give some thought to devising a similar device. Sure would be good practice.
Miller Bobcat 225
AHP AlphaTIG 200x
Lincoln SP-135+
ProStar O/A torch
AHP AlphaTIG 200x
Lincoln SP-135+
ProStar O/A torch
- DLewis0289
Electric ignitors, fireworks, 12 volt battery, overhead door opener and a few relay's, you are set.
- ldbtx
I just may have to start doing a little design work. Thanks.DLewis0289 wrote:Electric ignitors, fireworks, 12 volt battery, overhead door opener and a few relay's, you are set.
Miller Bobcat 225
AHP AlphaTIG 200x
Lincoln SP-135+
ProStar O/A torch
AHP AlphaTIG 200x
Lincoln SP-135+
ProStar O/A torch
