It is currently Sat Jan 20, 2018 8:46 pm Advanced search
4bt cummins alt bracket
Re: 4bt cummins alt bracket
Postby dzljon » Sun May 14, 2017 4:45 pm
Otto Nobedder wrote:Glad to have you back in one piece! Looks like you hit the ground running as soon as you opened the shop door.
BTW, The title of this topic has become a wee bit of an understatement. :lol:
I can rename it, if you would like a more appropriate title for what it's evolved into.
Steve
Thank! A new title is a good idea.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Jeep Cummins transplant specialist
dzljon
Postby Otto Nobedder » Sun May 14, 2017 4:52 pm
It's your topic, so let me know what you come up with. Or we could just add, "and then some..."
Steve
Otto Nobedder
Postby pgk » Tue May 16, 2017 4:36 pm
Wow! Nice looking project you have going on there, you should have some nice low end grunt on tap. 1 ton up front should be about unbreakable. Are you going with a locker also?
Pete
Esab SVI 300, Mig 4HD wire feeder, 30A spool gun, Miller Passport, Dynasty 300 DX, Coolmate 4, Spectrum 2050, C&K Cold Wire feeder WF-3, Black Gold Tungsten Sharperner, Ellis 1600
pgk
Postby dzljon » Wed May 17, 2017 6:18 pm
We are test fitting the exhaust now that we have the alt and ac compressor installed ImageImage
dzljon
Postby dzljon » Wed May 24, 2017 7:56 pm
Machined the crank sensor pulse pattern into the 4bt cummins harmonic balancer so the stock jeep tj tach will workImageImageImageImage
dzljon
Postby dzljon » Thu Aug 31, 2017 2:52 pm
Making he221w rurbo parts :) :P ImageImageImageImageImage
dzljon
Postby dzljon » Mon Oct 09, 2017 6:58 pm
Turbo clearance has been an issue but might have found a solution by turning the charger 90 degrees ImageImageImageImageImageImageImage
dzljon
Postby dzljon » Mon Oct 16, 2017 7:06 pm
Test fit looks decent so far ImageImageImageImageImageImage
dzljon
Postby dzljon » Sun Oct 22, 2017 9:27 pm
Started tinkering with the downpipe ImageImageImageImageImageImageImageImage
dzljon
Postby dzljon » Tue Oct 24, 2017 7:17 pm
Oil supply and return mocked in place ImageImageImage
dzljon
PreviousNext
Return to Welding Projects - Welding project Ideas - Welding project plans
