Page 4 of 4
Re: 4bt cummins alt bracket
Posted: Tue Dec 27, 2016 4:39 pm
by dzljon
I am still out of the country but my wife picked up a ford superduty front dana 60 that is waiting to be narrowed for the jeep
Sent from my SAMSUNG-SM-G890A using Tapatalk
Posted: Sat May 13, 2017 7:46 pm
by dzljon
We are back on the jeep project after spending time on deployment. ImageImage
Posted: Sat May 13, 2017 8:23 pm
by rick9345
Jim FLinchbaugh wrote:I'll admit to being a little envious. I really want to put a 4BT in my Tahoe, but the $$ is prohibitive.
By the time I get the engine, trans adapter and trans controller I'd be way upside down
when one gets emotionally involved with a project,one becomes blind to the cost. Join the club,but you will get bragging rights. ;) ;)
A professional car restorer will tell that the dreamer will generally realize 20-40% of the cost + brag when he sells the ride.
Posted: Sun May 14, 2017 2:39 pm
by dzljon
Driver side motor mount progress ImageImage
Posted: Sun May 14, 2017 4:41 pm
Glad to have you back in one piece! Looks like you hit the ground running as soon as you opened the shop door.
BTW, The title of this topic has become a wee bit of an understatement. :lol:
I can rename it, if you would like a more appropriate title for what it's evolved into.
Steve
Posted: Sun May 14, 2017 4:45 pm
by dzljon
Otto Nobedder wrote:Glad to have you back in one piece! Looks like you hit the ground running as soon as you opened the shop door.
Steve
Thank! A new title is a good idea.
Posted: Sun May 14, 2017 4:52 pm
It's your topic, so let me know what you come up with. Or we could just add, "and then some..."
Steve
Posted: Tue May 16, 2017 4:36 pm
by pgk
Wow! Nice looking project you have going on there, you should have some nice low end grunt on tap. 1 ton up front should be about unbreakable. Are you going with a locker also?
Pete
Posted: Wed May 17, 2017 6:18 pm
by dzljon
We are test fitting the exhaust now that we have the alt and ac compressor installed ImageImage
Posted: Wed May 24, 2017 7:56 pm
by dzljon
Machined the crank sensor pulse pattern into the 4bt cummins harmonic balancer so the stock jeep tj tach will workImageImageImageImage
Posted: Thu Aug 31, 2017 2:52 pm
by dzljon
Making he221w rurbo parts :) :P ImageImageImageImageImage
Posted: Mon Oct 09, 2017 6:58 pm
by dzljon
Turbo clearance has been an issue but might have found a solution by turning the charger 90 degrees ImageImageImageImageImageImageImage
Posted: Mon Oct 16, 2017 7:06 pm
by dzljon
Test fit looks decent so far ImageImageImageImageImageImage
Posted: Sun Oct 22, 2017 9:27 pm
by dzljon
Started tinkering with the downpipe ImageImageImageImageImageImageImageImage
Posted: Tue Oct 24, 2017 7:17 pm
by dzljon
Oil supply and return mocked in place ImageImageImage
Posted: Thu Oct 26, 2017 6:14 pm
by dzljon
Got to spend a few minutes working on the next piece of the exhaust ImageImage
Posted: Thu Oct 26, 2017 10:50 pm
There isn’t much room for anything but engine under that hood.
Posted: Tue Mar 06, 2018 4:45 pm
by dzljon
I have been dragging my feet on this project but have made some good progress lately ImageImageImage
Posted: Tue Mar 06, 2018 4:46 pm
by dzljon
Posted: Wed Mar 07, 2018 2:27 am
by Arno
dzljon wrote: Image
Looks nice and clean!
Not sure if it's still a mock-up but I'd be a little concerned about the oil feed hose routing to the turbo in the picture..
Seems it's now running between the manifold and the downpipe. Could get awfully hot there even though it's a diesel and the peak exhaust temps are way lower than a gas one. PTFE (lined) hose can run up to 400F or so, but it will start degrading from that point onward. Also seems a little un-supported which could cause issues with the vibrations and weight of the hose cracking the fitting/connection to the turbo in the long run. (what? a big diesel having vibrations? nooooo.. of course not! :roll: )
Spraying hot oil over a turbo or manifold usually in the 'uh oh.. I think this is not so good' category :lol:
Could you perhaps run the oil hose from the block under and away from the manifold, towards the firewall and then up the firewall to get to the turbo from the other side? Just so it's far away from any 'hot pipes' as possible and with as little strain/stress on the hose and fittings?
Bye, Arno.
Posted: Wed Mar 21, 2018 10:48 am
by pgk
That little 4bt should be a beast in that TJ, interested in seeing what your fuel mileage improvement will be?
