    Wed Oct 23, 2013 3:30 pm
    Palmer AK
This auger has had a bad lower bearing for years. Balls and cage toally gone.
Finally decided to replace it.
Screw gear pullers and set screws, I torched it all off.
Enjpy.
~John
There you be.
Only thing I did wrong was cut the keyway 1/8" to long.
Only had a vise crip and reciprocating saw.
Chain is kinda stiff so I'll soak it in oil or replace it.
Then she'll be ready for service.
Thanks for watching.
Looks about like a lot of the cooling tower / condenser fan stuff I get into. Hasn't seen grease since the day it was put in service! Nice work demo without destruction can be a fine line.
Well done. I use similar tactics in bearing removal.
I didn't think to take pics, as no welding was involved, but on reflection I did use a cutting torch to remove the old bearings recently on a 1HP 3-phase motor. I washed them off the rotor shaft just as you did in the picture. The trick is to have a super-clean tip that will cut precisely, then wash the inner race to within a 32nd of an inch. This is enough disruption to easily slide the remains off without cutting all the way through and risking scarring the shaft. It's a great technique to practice, as even with the proper press, fixtures, and fitting, an old rusty shaft will damage itself in the bearing's removal.
Then, I got to use my favorite tactic... I dropped the whole rotating assembly in liquid nitrogen for five minutes or so, until the boiling stopped, then basically slid the new bearings on by hand, with a couple gentle taps on a shaft-sized socket to confirm they were fully seated. Call it a different definition of "cold pressed"... :roll:
Another good one we should post is getting old twisted off pipe out and saving the threads they were screwed into.
    Sun May 01, 2016 7:46 am
    Fort Myers Florida
Poland308 wrote:Looks about like a lot of the cooling tower / condenser fan stuff I get into. Hasn't seen grease since the day it was put in service! Nice work demo without destruction can be a fine line.
Forida cooling tower work, guaranteed to make use lose 15lbs in one day.
