It is currently Sat Feb 24, 2018 10:08 am Advanced search
How to weld a crack in aluminum rv hot water tank
Ideas & suggestions for videos
Postby jjjspop » Wed Sep 20, 2017 3:59 am
Please can someone give me some advice on how to weld a crack in my rv hot water tank?
jjjspop
Re: How to weld a crack in aluminum rv hot water tank
Postby weldin mike 27 » Wed Sep 20, 2017 4:02 am
We're fine, thanks for asking.
weldin mike 27
Postby Poland308 » Wed Sep 20, 2017 6:56 am
You may want to offer up some more details like, what kind of metal it is, how thick is it, what kind of weld machines do you have access too, where is the crack or hole, what does the tank look like, is it corroded?
Postby Poland308 » Wed Sep 20, 2017 11:16 pm
It was relayed to me that it's an aluminum 3/16 tank that was cracked from frozen water. If you had to use a spool gun what settings would you use?
Postby AKmud » Thu Sep 21, 2017 2:02 am
It will be tough with a spool gun. The ones I've fixed are thin, like 18 gauge or smaller. I usually hammer them back in to shape and then just TIG them up. They are low pressure, so it's not all that difficult.
AKmud
Postby Poland308 » Thu Sep 21, 2017 10:54 pm
I believe the OP only has a spool gun.
Return to Wish List
