In a recent thread it was suggested to use silicon bronze to repair a pin hole in aluminum, so I thought I give a try to see what happens. I welded two 1/8" Al flats, drilled a hole and went for it.
Farmwelding
- Farmwelding
Since the aluminum melts at a lower temp that should be expected-silicon bronze and aluminum mixing kind of like steel and aluminum it isn't gonna work to well. I feel bad you had to ruin such a nice bead.
That is some nasty aluminum you have there though.
Instagram: @farmwelding
Nick
Nick
- 5th Street Fab
I tried yesterday too since I had it out. But tried on DC and it just wandered and rolled it upLtBadd wrote:In a recent thread it was suggested to use silicon bronze to repair a pin hole in aluminum, so I thought I give a try to see what happens. I welded two 1/8" Al flats, drilled a hole and went for it.
- 5th Street Fab
Hmm just looked really dull figured it was ac, I might try that and see if anything different happensLtBadd wrote:I did use Dc for the Silbrz weld5th Street Fab wrote:I tried yesterday too since I had it out. But tried on DC and it just wandered and rolled it up
I just ordered some Alum Bronz, holy crap that stuff is more expensive than I thought it would be. $15/lb & only a 10 lb box. I have a use for at least 3 lbs of it to save a $850 part on my sheet metal break, so it is worth it.
And I'll try it on aluminum and report back.
I have a friend who is going to send me a few sticks of sil-bro to try in exchange for some codes. One day.......
I guess I'm puzzled by this thread?
I've not seen any listings for sil-bronze or alum-bronze used for joining aluminum?
Did I miss something?
I recently used some alum-bronze rod to tig braze a cast iron piece - worked very well.
I expected it to though as the A2 alum-bronze I bought was specifically listed for cast iron and Jody had done a video on it as well (much appreciated by the way ).
The initial post is completely on the wrong track. No use for sil-bro or al-bro on aluminium. But as usual we hi jacked the thread.
As stated in the completely wrong initial post, someone else in another thread talked of using silbrz to fix a hole in AL, I just wanted to give it a try and see what happens, and here we are.MinnesotaDave wrote:I guess I'm puzzled by this thread?
I was a partial contributor to that fiasco, and I apologize. We were discussing a 16 gauge aluminum fuel tank. These phrases do not belong together, since an aluminum fuel tank should be 11 gauge, at least, and I replied on the Si-Br while thinking stainless steel, which would be more appropriate at that thickness. I opened my mouth after pouring beer down it, and confused the issue.
Happens to all of us....try vodka next timeOtto Nobedder wrote:I was a partial contributor to that fiasco, and I apologize. We were discussing a 16 gauge aluminum fuel tank. These phrases do not belong together, since an aluminum fuel tank should be 11 gauge, at least, and I replied on the Si-Br while thinking stainless steel, which would be more appropriate at that thickness. I opened my mouth after pouring beer down it, and confused the issue.
Have a fine bottle of it in the fridge, as I type this.exnailpounder wrote: Happens to all of us....try vodka next time
Mine is out of the fridge as I type this. Going slow because I have to pick the wife up soon but after thatOtto Nobedder wrote:Have a fine bottle of it in the fridge, as I type this.exnailpounder wrote: Happens to all of us....try vodka next time
I have to work tomorrow, so it's beer tonight, as the vodka gets cold alongside the tomato and orange juices for various concoctions I may choose to make.exnailpounder wrote:Mine is out of the fridge as I type this. Going slow because I have to pick the wife up soon but after thatOtto Nobedder wrote:Have a fine bottle of it in the fridge, as I type this.exnailpounder wrote: Happens to all of us....try vodka next time
As I recall from the last podcast with Jimmy Diresta, he said always be willing to experiment. I didn't try that to see if it would work, but to see what would happen.Otto Nobedder wrote:I was a partial contributor to that fiasco, and I apologize. We were discussing a 16 gauge aluminum fuel tank. These phrases do not belong together, since an aluminum fuel tank should be 11 gauge, at least, and I replied on the Si-Br while thinking stainless steel, which would be more appropriate at that thickness. I opened my mouth after pouring beer down it, and confused the issue.
Below is something I did many years ago on another job, we had purge chambers for Ti parts and we'd use these Ti coupons for a test weld to see if the chamber was ready, I used Inco 62 filler just to see what would happen, I thought it looked cool and kept it all these years.
The coupon looks dark because, well it's been around awhile
- Img_0506.jpg (29.95 KiB) Viewed 1036 times
Fossilized weldipede?LtBadd wrote:As I recall from the last podcast with Jimmy Diresta, he said always be willing to experiment. I didn't try that to see if it would work, but to see what would happen.Otto Nobedder wrote:I was a partial contributor to that fiasco, and I apologize. We were discussing a 16 gauge aluminum fuel tank. These phrases do not belong together, since an aluminum fuel tank should be 11 gauge, at least, and I replied on the Si-Br while thinking stainless steel, which would be more appropriate at that thickness. I opened my mouth after pouring beer down it, and confused the issue.
Farmwelding
- Farmwelding
Fossilized centipede? Why isn't that in a museum. Gosh I better call the museum of welding up and tell them you have it.
Nick
Nick
A grass hopper walks into a bar. The barman says "we've got a drink named after you...." "Wow.." says the grasshopper. "Who would call a drink Kevin"
I'm telling that to my friend, Kevin, on Monday.weldin mike 27 wrote:A grass hopper walks into a bar. The barman says "we've got a drink named after you...." "Wow.." says the grasshopper. "Who would call a drink Kevin"
Farmwelding
- Farmwelding
Nick
Nick
They have a drink named after me, too. I call it "Sex on the Beach."
My wife calls it, "Sand in the Vagina Sucks!"
A grass hopper walks into a bar. The barman says "we've got a drink named after you...." "Wow.." says the grasshopper. "Who would call a drink Kwai Chang Caineweldin mike 27 wrote:A grass hopper walks into a bar. The barman says "we've got a drink named after you...." "Wow.." says the grasshopper. "Who would call a drink Kevin"
- WoodpeckerWelder
One would have to be of a certain age to appreciate that one....LtBadd wrote:A grass hopper walks into a bar. The barman says "we've got a drink named after you...." "Wow.." says the grasshopper. "Who would call a drink Kwai Chang Caineweldin mike 27 wrote:A grass hopper walks into a bar. The barman says "we've got a drink named after you...." "Wow.." says the grasshopper. "Who would call a drink Kevin"
"Why is there never time to do anything right the first time but always time to do it again?"
