My welder arrived Monday, and I finally got to fool with it tonight. I am trying to assemble the torch. I have a stupid question.
The torch is a size 17, and it came with three collets. The first tungsten I ground was 1/8", so I figured I would assemble the torch with that, using the biggest collet. When I tried to do it, the tungsten fit in the collet fine, but it would not go through the bore of the collet body.
What's going on? I just assumed that three collets with the same OD meant all would work with the same collet body, but I don't think I can get the tungsten through the body without drilling it out.
- Chips O'Toole
- Chips O'Toole
It's the basic torch and cups that came with the welder. Not a gas lens. The collets are fine. It's the collet body that's small. It will work with 1/16 and 3/32, but it's too tight for 1/8.
The collet body also unscrews. It' has to match the same size as the collet.
- SR17_prts.jpg (46.88 KiB) Viewed 913 times
It could be the wrong sized collet for the tungsten, but you aren't supposed to drill anything. My collets are marked for each size up near the top.Chips O'Toole wrote:My welder arrived Monday, and I finally got to fool with it tonight. I am trying to assemble the torch. I have a stupid question.
One way to assemble is to remove backing cap/tungsten cover and insert collet, then tungsten, then tighten down the back cap/tungsten cover. On mine (cheap abicore binzel that comes with chinese machines) the back cap tightens and snugs up the collet and tungsten. If the back cap is on it will be hard or impossible to put the collet and/or tungsten in.
- Chips O'Toole
The collet fits fine. The collet BODY is too tight.
Step 4: Cup of your choice on the front, adjust stick out a little, place back cap on the back. Snug down back cap to tighten up the tungsten so it doesn't get crazy on you.
- 0310172213.jpg (26.57 KiB) Viewed 790 times
- Chips O'Toole
The 1/8" collet fits the collet body just fine. That's why I thought it was weird that the tungsten would not go through the collet body.PeteM wrote:Does the collet for the 1/8 tungsten fit into the collet body?
When they're brand new, before everything gets hot and cold a few times, they can be a little snug. I don't know if anybody does it any differently, but I find it helps to do them in that order so that you can give the tungsten a good shove when it needs it.Chips O'Toole wrote:The 1/8" collet fits the collet body just fine. That's why I thought it was weird that the tungsten would not go through the collet body.PeteM wrote:Does the collet for the 1/8 tungsten fit into the collet body?
Hope that helped, and happy tiggin'.
CanMoulder
- CanMoulder
each size tungsten has a specific collet body size
so if you change the tungsten size you have to change the collet and the body
https://images-na.ssl-images-amazon.com ... nWLQPL.jpg
also the paint on the end of the tungsten can be to large if trying to slide in from the open end
Kevin
Kevin
