Mihtu
    Sun Feb 12, 2017 11:01 am
    Upstate New York
More pics
If your using windows, before you upload you can rotate easily by "right clicking" on the pic and select either rotate clockwise or counterclockwise
Be sure your cursor in where you want the pic to go BEFORE you select "Place inline"
Hope that's clear
Mihtu
    Upstate New York
If you want dimensions,I can come up with something,probly wouldn't be all that difficult to make you a drawing,I actually built it fron the picture I saw,then cut and welded what seemed to make sense,the guy who originally built one,tried to post instructions,but they threw me off a bit,kinda not in order,so I figured what have I got to lose,$3 in scrap and some practice,just so happens it actually worked!
PhillerTime
    Tue Jan 24, 2017 1:15 am
Looks like it works great!
Sent from my Nexus 6 using Tapatalk
    Mon Feb 13, 2017 4:53 pm
    NW Fla
I would love some dimensions, that looks like a natural winner !!!!
creek
Mihtu
    Upstate New York
Base for bench is 2 inch angle,you need an 8",and a 16" piece, the upright for axle are 8" also,the mandrel is a piece 24" long bent around a b-tank.then 2 pieces 6" long,I bent and welded the loop,then added in the 6" pieces, how I positioned them is put a level on the top flat,then added the 2 in the perfect verticle position,found the center ,drilled a half inch hole,for the axle bolt,which I welded to the 2 6" pieces,the rib on the back is a little too big,but it's what I had,1/8" solid rod,the cleat is 2 7" pieces with a roller,and another on top to hold the tubing when you pull it through!
Mihtu
    Upstate New York
Bender pictures
    NW Fla
Thanks M !!
