- snip_20170320184338.jpg (13.9 KiB) Viewed 2174 times
- snip_20170320184458.jpg (23.85 KiB) Viewed 2174 times
- snip_20170320185417.jpg (7.58 KiB) Viewed 2174 times
Hope that's clear
If you want dimensions,I can come up with something,probly wouldn't be all that difficult to make you a drawing,I actually built it fron the picture I saw,then cut and welded what seemed to make sense,the guy who originally built one,tried to post instructions,but they threw me off a bit,kinda not in order,so I figured what have I got to lose,$3 in scrap and some practice,just so happens it actually worked!
PhillerTime
- PhillerTime
- Granddaddy
I would love some dimensions, that looks like a natural winner !!!!
creek
creek
Base for bench is 2 inch angle,you need an 8",and a 16" piece, the upright for axle are 8" also,the mandrel is a piece 24" long bent around a b-tank.then 2 pieces 6" long,I bent and welded the loop,then added in the 6" pieces, how I positioned them is put a level on the top flat,then added the 2 in the perfect verticle position,found the center ,drilled a half inch hole,for the axle bolt,which I welded to the 2 6" pieces,the rib on the back is a little too big,but it's what I had,1/8" solid rod,the cleat is 2 7" pieces with a roller,and another on top to hold the tubing when you pull it through!
Bender pictures
- 20170329_222416.jpg (25.96 KiB) Viewed 1911 times
- 20170329_222623.jpg (38.52 KiB) Viewed 1911 times
- 20170329_222409.jpg (27.87 KiB) Viewed 1911 times
- 20170329_222611.jpg (47.58 KiB) Viewed 1911 times
- 20170329_222322.jpg (40.09 KiB) Viewed 1911 times
- 20170329_222309.jpg (40.74 KiB) Viewed 1911 times
- 20170329_222246.jpg (36.9 KiB) Viewed 1911 times
- Granddaddy
Thanks M !!
