TLAR....I'm gonna steal that from youOtto Nobedder wrote:Gap-o-let? I just cut the threads off the pipe section you see (Originally a threaded nipple. I was expecting Rego valves, with FNPT both ends). I then loosely fit these ITT valves (this has a mate exactly opposite) for the standard 1/16" minimum pull-back for a socket weld, used my electrician's level to set the valves at 30*, and a quick tack on top. Squared them up with my TLAR (That Looks About Right), and welded them out.
Be my guest! I also estimate time on task by the WAG method, which is "Wild-Ass Guess". I always look like a hero, because I use Thomas Edison's rule... However long I think it will take, I double it, then add ten percent, and that's what I tell them.exnailpounder wrote:TLAR....I'm gonna steal that from youOtto Nobedder wrote:Gap-o-let? I just cut the threads off the pipe section you see (Originally a threaded nipple. I was expecting Rego valves, with FNPT both ends). I then loosely fit these ITT valves (this has a mate exactly opposite) for the standard 1/16" minimum pull-back for a socket weld, used my electrician's level to set the valves at 30*, and a quick tack on top. Squared them up with my TLAR (That Looks About Right), and welded them out.
Under-promise and over-deliver, and they'll beat down your door.
- RocketSurgeon
It's been a while since I posted anything substantial.
First time on 304 SS 1 1/2", 1" and 1/2" sch 40. Two passes. Argon purge at 10cfh. 3/32 2%Thoriated with #7 cup (wishing it was an 8).
- 20170414_123353.jpg (27.59 KiB) Viewed 2077 times
- 20170414_123345.jpg (30.78 KiB) Viewed 2077 times
- 20170414_123334.jpg (41.7 KiB) Viewed 2077 times
- 20170414_084546.jpg (37.97 KiB) Viewed 2077 times
- 20170414_084535.jpg (38.37 KiB) Viewed 2077 times
- 20170414_084517.jpg (28.34 KiB) Viewed 2077 times
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
- GreinTime
Getting the hang of these exhaust flex sections! 3" 304, backpurge at 7cfh, welded at 90a w/ 1/16"308L. Pictures arranged chronologically from out of the bag to welded, for those of you who have never had the unfortunate pleasure of welding one!
Great job Sam! I know you like bells and whistles...did you pulse these? You got great color.
- GreinTime
No, these guys are anti pulse lol. I welded 1/2-5/8" at a time, mainly because that outer shell is 0.020-0.030" thick in some places. Monster 16 nozzle at 40-45cfh. I don't remember if I included that bit.exnailpounder wrote:Great job Sam! I know you like bells and whistles...did you pulse these? You got great color.
- MosquitoMoto
Beautiful work Sam.
Pete
Pete
Pete
Here's a random batch of pics from stuff I've been working on, I do post on my Instagram account a good bit of your interested. RNHFAB
- 1/2" sanitary
- IMG_20170328_175012461.jpg (56.47 KiB) Viewed 2243 times
- Vertical up
- IMG_20170404_172122181.jpg (52.94 KiB) Viewed 2243 times
- IMG_20170405_202821093_HDR.jpg (76.37 KiB) Viewed 2243 times
- IMG_20170410_194608740.jpg (37.99 KiB) Viewed 2243 times
- All finished
- IMG_20170411_150122481.jpg (50.43 KiB) Viewed 2243 times
- IMG_20170412_203129106_HDR.jpg (40.37 KiB) Viewed 2243 times
- IMG_20170414_205050865.jpg (66.56 KiB) Viewed 2243 times
- 5th Street Fab
Everyone, please remember... When you're looking at work that impresses you, work that makes you question your own, you are looking at goals. Objectives. The place you want to be with a few years' more experience.
NONE of these weldporn jockeys came out of the womb doing that, and every one has had their share of epic fails before they got consistent, and a few more before they were good.
NEVER put yourself down because your weld doesn't look like so-and-so's. If you're six months in, and he's been doing it 30 years, you can't expect to be on par.
jernigan78
- jernigan78
Aloha guys. Ill jump in on this. Some stuff from this week. Mostly fishing stuff. 316 stainless stuff. Mahalo
- IMG_7576.JPG (35.98 KiB) Viewed 2025 times
- IMG_7789.PNG (1.68 KiB) Viewed 2025 times
- IMG_7909.JPG (73.03 KiB) Viewed 2025 times
And also realize..if you do the same thing every day you better damned well get or be good at it or you'll be down the road. It's the guys that have to wear all the hats that impress meOtto Nobedder wrote:Everyone, please remember... When you're looking at work that impresses you, work that makes you question your own, you are looking at goals. Objectives. The place you want to be with a few years' more experience.
Recycling an old filler bowl to make something else...
.065" tubing, .020" bowl
- IMG_20170421_203131087.jpg (43.47 KiB) Viewed 2199 times
- IMG_20170421_201304071.jpg (52.01 KiB) Viewed 2199 times
I welded something by mistake thinking it's aluminum casting but it worked.... what the hell?
It's too heavy and fairly magnetic. The aluminum stuck....what is it?
- 14928317115601875884036.jpg (35.11 KiB) Viewed 2174 times
I can't post 2 pictures for some reason...
- Pic
- 149283211206945241914.jpg (38.52 KiB) Viewed 2159 times
Made this smoker box for a friend this weekend. Adding legs right now. One heavy SOB 1/4 inch plate 22 by 14 inches. Putting a grate inside tomorrow.
- Als smoker 2.JPG (54.34 KiB) Viewed 2114 times
- Als smoker 3.JPG (47.37 KiB) Viewed 2114 times
- Al smoker 1.JPG (64.4 KiB) Viewed 2114 times
