It is currently Wed Jan 17, 2018 9:02 am Advanced search
video suggestion : dig function practical effect
Ideas & suggestions for videos
Postby olek » Mon Jul 17, 2017 11:52 am
It is about the "dig" function, and how it modify the arc behavior, how it can be regulated depending of the rod and the job at hand
I am often training on thin steel, as 3/8 and even less, so the "arc force/dig function is not helping, as I had a feeling that my arc is too much invasive often.
When I begun to feel at ease with what I see, and the arc length management, I discovered that to understand the amp regulation I'd better put the dig function at its minimum, or even off
And I understand way better how the arc is working relatively at it's size.
It makes less sparkles
and I have no undercut due to very short arc plus dig.
if you think it is possible to make a clear enough demonstration of the arc with an without the function, describe a little the curves, and summarize the subject, that would be interesting, I think
SO, do you think it would be doable , and of some interest ?
Pianos , restorer and tuner
Dedicated to learn welding since april
slowly learning ;) not complaining of doing beads and beads
pro inverter PROGYS 200 FV PFC CEL+tig lift
OA Oxyflam 1000 cutting and welding gas torch
olek
Return to Wish List
