So I currently have a small 27" X 27" table that I made for O/A welding with a fire brick surface. For practicing TIG, I threw a piece of 3/16 steel on top of it that is about 10"X 30", but it isn't very flat. It's great for practice, but really won't do for projects.
I have a 48X96 table that I made out of OSB, and I have a roll of .032 2024 T3 Alclad that I haven't used for about 20 years that has been sitting around. I'm thinking of putting a piece of MDF on top of my existing table so I have a nice flat surface, then cutting a 48X96 piece of the 2024 Alclad to put over it so I have a metallic surface to ground to. 2024 is not a weldable alloy. It's all materials that I already have, so it's cheap! Would the .032" 2024 be a reasonable surface for a welding table, or would it warp and twist on the first application of heat? Would I be better off just using the MDF and ground to whatever project is at hand?
My other thought is to get a FabBlock but that's lots of $$. Main advantage is that it would be more mobile depending on size, and it is set up with holes on a 2" grid for modular tooling. I've got enough room in the shop that I could keep my existing table and still fit a 24X48 FabBlock. By the time I buy the FabBlock, legs, castors and shipping I'd have almost $800 into that table.
While you might gain a little bit of a benefit from covering the mfd with the aluminum.i would wager that in a very short time the aluminum will get chewed up from arcing if you use it to ground to. If it's free, use it to add a little extra resistance to the mfd from sparks, but don't try to ground through it, it will just give you ground problems.
I bought and made my own 48"x72"x0.75" for under $500. A piece of 1/2" would be thick enough, but 5/8" is better. I used a Mag drill to drill the holes (took a while) and if you don't have one, you can rent one pretty cheap.
- IMG_0415.JPG (55.55 KiB) Viewed 2277 times
That's a lot of holes to drill!cj737 wrote:I bought and made my own 48"x72"x0.75" for under $500. A piece of 1/2" would be thick enough, but 5/8" is better. I used a Mag drill to drill the holes (took a while) and if you don't have one, you can rent one pretty cheap.
David
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
DrivenToMake
- DrivenToMake
I bought a certiflat table from Tab and Slot myself. If I had it to do over again, I would not buy a table with all the holes in it.dgapilot wrote:So I currently have a small 27" X 27" table that I made for O/A welding with a fire brick surface. For practicing TIG, I threw a piece of 3/16 steel on top of it that is about 10"X 30", but it isn't very flat. It's great for practice, but really won't do for projects.
But that is me personally, for the projects that I've done thus far. The fixture tables are mostly beneficial if you are building vertically. And especially if you are setting up fixtures for batching things out.
One thing that really annoys me about my certiflat table, is the insert holes are not as square as I would like when setting up a 90*. And regardless of the torsion box style webbing that you weld together on the bottom side, it's really not all that flat. The webbing on the underside also gets in the way of certain clamps when you want to clamp from the under side of the table. Clamping at the edges, also a pain. Might be better on a Fab Block than my pro table, not sure.
If I were to do it over, I would get a 1/2 to 5/8 slab that is 3 ft x 4 ft. And then I would invest in things like 1-2-3 blocks, 80/20 extrusions etc for creating set-ups. Then if I needed to build vertically, I would get some of the Fab Squares from Tab and Slot, or possibly something from Fireball tools.
Strategically drilled and tapped holes, like an x pattern through the table would serve just as well as the full grid, and wouldn't require gingerly threading a bolt into the magnetic adapter.
The holes, tabs and slots tend to catch things as well. They'll catch a weld bead and prevent you from rotating your part without lifting the part off the table.
The sum of all the (minor) annoyances, in my mind, have been greater than the benefits of the fixture table itself.
I sort of made out though, because the first table arrived damaged, and they sent me a second table (top only) for free.
I'd gladly trade both of these for a thick slab.
Sent from my SM-G925V using Tapatalk
The thing I found on my prop table (same size, just a lot fewer holes) was that wherever I needed a hole, I didn't have one. I was always a 1/2" too far off it seemed. So the denser pattern became a must have. I fab and weld too many different things too frequently. I use Strong Hand quickies and G clamps and vise clamps and always have what I need. You could also drill as you need a hole if you own a mag drill and simply start with a few holes to get you going.
My opinion, thicker is better. It is more sturdy, resistant to heat warpage, and you can plop anything on it without a care in the world. Had my slab Blanchard ground top and bottom for flatness. Not 0.000 accuracy, but neither am I.
My first table (3x6) with a 11/2 x3in tubing frame ( perimeter and 2 stringers lengthwise) I had the local fab shop weld the perimeter frame only on their large flat worktable to get it flat as possible. Then I was able to finish it myself once I had the flat frame. It has a 1/4in top with a 2in lip all around for edge clamping and of course wheels ( my must have for anything not bolted down). My 2nd table ( 3x5) I simply built upside down on top of table one.My 3rd table,a cutting table (6x30in) ditto. All my projects are "one of" and with assorted clamps,magnets (steel only)and various misc. rigs and jigs I can pretty much handle whatever I need with decent accuracy. The 1/4in plate is plenty heavy enough with the ridgid subframe and no grounding problems. I have never worked with a table with the jig holes but have always been able to do a workaround with no problems.
Make a table, it is good practice/a good learning experience. I made two recently. One is a sit down work station about 30x30 inches, 1/2 is a cutting surface and the other 1/2 is a really flat plate for welding on. The other table is a 3x5 foot table made of 2x2x1/8th inch square tube, and 3/8ths inch plate. The larger table cost the most, about $300 in materials. Welded them both up with my MIG welder.
- 20170205_205601.jpg (49.39 KiB) Viewed 2223 times
- 20170205_205612.jpg (53.04 KiB) Viewed 2223 times
- 20170806_145740.jpg (45.72 KiB) Viewed 2223 times
- 20170806_135354.jpg (48.29 KiB) Viewed 2223 times
Multimatic 255
Oh yeah, and both of these were done on my garage floor which is not level. Use a good framing square that you have proven to be square (lots of videos out there on how to do it). Don't over weld. You can get it as flat as you need it to be if you are careful. DON'T use a level unless you know for a fact you are working on a perfectly level surface. You don't need fancy corner clamps either. Tack it in one corner (Jody has videos on this), square it in one direction, put a second tack, and square it in the other direction. Lock it down with 4 tacks total. Watch the videos on weld correct weld sequence and weld it all up. Do not over weld. Heat distorts everything. You have to plan ahead for it.
Multimatic 255
That's why they make leveling casters...Louie1961 wrote:Oh yeah, and both of these were done on my garage floor which is not level. Use a good framing square that you have proven to be square (lots of videos out there on how to do it). Don't over weld. You can get it as flat as you need it to be if you are careful. DON'T use a level unless you know for a fact you are working on a perfectly level surface. You don't need fancy corner clamps either. Tack it in one corner (Jody has videos on this), square it in one direction, put a second tack, and square it in the other direction. Lock it down with 4 tacks total. Watch the videos on weld correct weld sequence and weld it all up. Do not over weld. Heat distorts everything. You have to plan ahead for it.
I defiantly will need casters on whatever table I make or buy. I've also been watching Craigslist to see if something pops up. Biggest problem is finding something I can wrestle around myself with just an engine hoist.
David
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
Once you have casters on worktables you will never go without especially in a smaller shop like mine where the furniture has to be rearranged for different projects. Make sure they have plenty of load rating for the heaviest possible job. On my first table I had to upgrade after a wheel collapsed when I grossed out with table and project at aprox.1000lbs. Another tip if you are using an engine hoist is leave enough space under the bottom shelf/supports to let the hoist legs pass under the table for loading and unloading the heavy stuff without breaking your back.
So I ordered a 36x48 fab block from weldtable.com and it arrived Monday. Started assembly today. Got everything together and while checking it out before welding, found a section that wasn't seated properly. Took it all back apart, did some debuting and reassembled. Now I can't get a .003" feeler gage between any of the ribs and the top. I'll let it sit overnight and start welding tomorrow. I don't have a mig, so this one will be all tig.
David
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
No pics today, got most of the top welded up, just one more side to finish up. Wish my skill level was a little better. Set the Everlast 210EXT to 210 amps, 5 second down slope, end amps of 5, start amps of 5 and upslope of 1 second for all the tacks. Finish welds I lowered to 180 amps. All done 2T with the switch on the torch.
David
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
Yes, 1/4 thick. Torsion box design. From these guys https://weldtables.com
David
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
sounds hot... If these were just tacks, why some much amperage? 1/4" steel is easily and fully welded with a lot less heat.dgapilot wrote:No pics today, got most of the top welded up, just one more side to finish up. Wish my skill level was a little better. Set the Everlast 210EXT to 210 amps, 5 second down slope, end amps of 5, start amps of 5 and upslope of 1 second for all the tacks. Finish welds I lowered to 180 amps. All done 2T with the switch on the torch.
I lowered it to 180 after a while. I was trying to get in and get out quick. Didn't work quite the way I wanted. Inexperience is the biggest issue. Got it all stuck together! Given my level of experience, it came out OK.cj737 wrote:sounds hot... If these were just tacks, why some much amperage? 1/4" steel is easily and fully welded with a lot less heat.dgapilot wrote:No pics today, got most of the top welded up, just one more side to finish up. Wish my skill level was a little better. Set the Everlast 210EXT to 210 amps, 5 second down slope, end amps of 5, start amps of 5 and upslope of 1 second for all the tacks. Finish welds I lowered to 180 amps. All done 2T with the switch on the torch.
David
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
David, looks good, you have to experiment to find out what works, seems you got it done, that's how we all improvedgapilot wrote: I lowered it to 180 after a while. I was trying to get in and get out quick. Didn't work quite the way I wanted. Inexperience is the biggest issue. Got it all stuck together! Given my level of experience, it came out OK.
If I ever build another, hopefully I'll have a mig. With the tig it took the better part of 2 1/2 days. Not really a beginner project, and definitely not advisable for one person with no help! I learned how far I have to go in building my skills. Someone mentioned about 2 or 3 bottles of argon by the time the welds look acceptable. I think that's about the truth.
David
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
