AnvilJack wrote:Well done. You are certainly past the point of "stopping in frustration", so that is very good.
The first big hurdle for beginners, I think, is learning to watch (and then control) the puddle.
Could I urge you to start making stuff at home. I am glad you have your own welder (a MIG). Try to do about ten hours welding a week for a few months. That's a lot, but it really helps crossing into the realm of being practical, useful, productive, and technically capable. In any case, weld often, and for several hours at a time, if you can. Buy (find) stuff like tube steel (30mm SHS), and make box frames, if you have nothing particular in mind. Wonderful training in measuring, cutting, fit up, joining, welding out of position, etc. Keep your tape, magnets, level, square handy all the time. Try destructive testing. Then cut the frame up when you are finished, if you like, and go again. (Of course, this is just ("good quality") busy work, if you don't have real projects immediately at hand.)
Welding thin sheet also helps to focus the mind.
How does your home workshop compare with "school"?
You are off to a good start. Beaudy.
artv wrote:Looks like you are doing good and are having fun. When I learned 35 years ago, we just ran 6010 until we could run it in our sleep. Made 2" Xs and filled them up in all positions. We wanted to try other processes, but the instructor told us that when we could run 6010 anywhere, we could use anything anytime. He was almost right, I had to learn gas separately. Practice is critical, and a lot of it. Learn to watch and control the puddle, practice, practice, practice.
Art
Awesome - thanks both for the good advice. Learning to watch the puddle was the one area that the instructor spent the most time, and what why he started us with torch welding, before stick, MIG, and finally TIG. But yes, I need LOTS of practice now.
My workshop is very small compared to the welding classroom at Eastfield College (Mesquite) where I took the class. My first project is a small welding table on wheels (so that I can move away when not being used). I plan on making the frame out of 2"x2" by 1/4" angle steel. Casters are 6" dia by 2" wide, hard, and the top will be 24"x36", 1/2" thick steel.
Will
