    Wed Nov 19, 2014 8:20 pm
    S.W. Pennsylvania
Was welding yesterday and noticed a leak at my cooler. Turns out the fitting cracked. Any suggestions on where to buy these? First place I checked the part was over $10 and the shipping was $7.95 :mad: Image
Brian
Brian
Miller Thunderbolt 225 AC/DC
Everlast 255EXT with W300 cooler
Hobo Freight 170 MIG Welder
At first glance it almost looks like a regular fitting, but then I saw the other end of it.
You should just retrofit that water line itself with the 9mm male quick-disconnect. That way you don't have to worry about any threaded fittings for it. It's redundant IMO.
Brian, go to Western Enterprises and click on their "Where Can I Buy?" at the top. The link I've provided will take you to the Quick Connect page where you can see what they have to offer.
It looks like Oscar has the QDB74 (hose to machine) (don't quote me on that :( )
BTW I've never seen a fitting fail like that, lucky you! :o
Sandow
    Fri Mar 04, 2016 4:52 pm
    Central VA
Dare I say... Weld it back together with some bronze. :)
-Sandow
-Charles Dickens
rahtreelimbs
    Mon Jun 14, 2010 10:39 pm
If you should decide to go with a quick disconnect fitting HTP.....(USAWELD.COM ) has them at a good price.
    Sun Sep 22, 2013 10:14 am
    Minneapolis Mn 55407
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
and these red,blue and gold available
http://www.riverweldstore.com/index.php ... ts_id=7825
Everlast 250EX
auto supply has fuel crimp on clamps that work.
NAPA #730-4991
http://www.napaonline.com/napa/en/search/?text=730-4991
They also have a 3/8 size for, the large hoses, (automatic trans cooler lines)
Everlast 250EX
OzFlo
    Sat Sep 26, 2015 10:16 pm
    Sydney, Australia
Hi Brian,
Have you had a look here?
http://weldfabulous.com/ck-worldwide-qd ... pter-plug/
Flo
OzFlo wrote:Hi Brian,
Flo
I've been thinking and thinking about it, and I still can't see the point of them other than perhaps they came about before they made the small 9mm male plug with the barbed end. :?:
    Sat Mar 30, 2013 11:49 am
    Sweden
Agree Oscar, the less possible leak points the better.
OzFlo
    Sydney, Australia
Oscar wrote: I've been thinking and thinking about it, and I still can't see the point of them other than perhaps they came about before they made the small 9mm male plug with the barbed end. :?:
That's cool but the OP wanted to know where to buy them. I was merely answering his question. I guess CK don't have a pre-fabbed hose with the 9mm male as standard - hence the "second best" option.
    S.W. Pennsylvania
Thanks guys! OzFlo thanks for the link. I ordered two of them..one for a back-up. I also used a coupon code to take 10% off.
Brian
Brian
SmartDave
    Fri Dec 19, 2014 12:43 pm
    Bellingham, MA
Arc-zone has those exact fittings
