I don’t like those plexiglass cheater lenses. I use optical, glass cheater lenses in my helmets. My method of fixing is to bond, using epoxy resin, a 3” length of 3mm mild steel filler to each side of the filter lens unit retaining piece, and also bond 4 round neodymium magnets (2 or 3 mm thick) to the corners of the cheater, also using epoxy resin. I have a selection of about 4 or 5 different strength lenses, depending on the distance away I want to hold my head, and swapping lenses over is easy, and they stay in place. I’ll try and upload some photos; it might help give someone ideas in the future.
Edit: some photos. SORRY - having big problems getting them in the right place, but I’m sure the message will get across.
The neodymium magnets are so strong that they will force each other off as the epoxy cures, so I wrap a mild steel plate in paper tissue, which holds the magnets in place and flat, with the lens placed on the magnets. I abrade the plastic to make a mechanical key for the epoxy to bite.
Here I have attached twin lengths of filler wire either side of the inner lens
- 97C397A3-B3BD-4D23-9644-979987C73C1E.jpeg (510.69 KiB) Viewed 6795 times
Here is a selection of my cheater lenses
The larger lens is a Best Welds lens; the 2 pale blue lenses are Optivisor lenses
