jeffBrian
    Sun Jan 31, 2016 1:36 am
    not the right place
I was considering buying a tig finger from jody but I don't tig. I usually run wire. I can see it useful for Some out-of-position work. does anyone else use the tig finger for welding other processes? I want to purchase a tig rig this summer sometime. so I can tell the wife that's why I bought it..
I use mine a lot on long runs of MIG also.
Miller Bobcat 225
Tweco Fabricator 211i
AHP AlphaTIG 200x
Lincoln SP-135+
Hypertherm Powermax 30 Air
ProStar O/A torch
jeffBrian
    not the right place
8-)
BIGTIME
    Fri Feb 26, 2016 9:21 pm
    Minnesota
I use one when you free hand in the field. On fitting when the pipe or fitting gets to hot.
Bugel
    Tue Apr 01, 2014 9:52 pm
ldbtx wrote:I use mine a lot on long runs of MIG also.
Agree..on long runs,gloves alone cannot handle the heat..tig finger glides smoothly in metal resulting no pause and consistent welds..
Rick_H
    Sat Feb 08, 2014 1:50 pm
    PA/MD
I use mine as well to help block heat or prop on for all processes...worthy small investment.
I've even used mine while washing welds off with a plasma cutter... That's a lot of heat build-up fast, and I'm already using heavy gloves, but the Tigfinger XL fits on the pinky of the heaviest gloves.
jeffBrian
    not the right place
I'm getting one! Tigfinger Migfinger
the pics you shared reminded me of these I did a while back. I didn't have a migfinger yet tho...
jeffBrian
    not the right place
I got the TiG finger bundle! thanks Mr. Jody!
2016-03-11 11.14.18.png (161.76 KiB) Viewed 1475 times
