This is the welder and my welding table, it's onwheels so I can roll it outside for welding work:
I am into homemade tools as well, this simple belt grinder has been very useful, it was primary intended to sharpen chisels, but it gets used for all kinds of metal shaping, eventually I will build a bigger metal belt grinder.
I recently made a sheet metal brake, also the vise is homemade:
motox wrote:
HTP 221
miller 250 syncrowave
miller 140mig
electrode wrote:
Ditto except my mig is a Hobart Handler 210 (220V only) and Oxy/Acet rig, and Hypertherm plasma cutter. And plenty of machine shop machines.
hypertherm plasma too, should have bought the 210 instead of 140. here to plenty of machine shop and fab tools.
Miller 252 with spool gun
A Miller Dynasty 280 in the near future
72" x 40" x 1-1/4" welding table blanchard ground flat
Butt loads of clamps
CNC mill
CNC lathe
CAD and CAM software
Manual mill and lathe
4' x 6' x 10" surface plate and lots of precision measuring tools
Lots of good quality hand tools
Martin 00016 guitar
JBL sound system
2400 SF to put them in
I use this shop to make a living in but it is also my man cave. I'm there 7 days a week.
Welders
Lincoln 100 fluxcore mig, My first Mig experience.
Millermatic 140, I like this machine alot
L-Tec 250 heliarc with bernaard cooler and 18 torch, Like it alot! Stickwelds like a dream too!
WW 2 era Gisholt turret lathe
WW 2 era Milwaukee Horizontal compound table mill, I have made gears on this machine
Acet and ox
Harris E-16 I use for brazing and small stuff
A bigger smith for heavier cutting and rosebud work.
14" Chop Saw
Chinese Band saw
3 Angle grinders
Die Grinders
F clamps
Visegrips
I like making things from Steel, Stainless And Aluminum. Woodworking is NOT for me.
Lincoln Ranger 8 (only 98 hours) and an AC/DC buzz box
3x Miller Dialarc 250s, two white face, one black face
An old Astro MIG 120 volt wire feed welder
Lance
LanceR
Miller Multimatic 255
Hypertherm Powermax45 XP
Heck Bevel Mill 4000
Ace fume extractor
Welding/cutting/brazing torches
Miller Passport, Dynasty 300, Spectrum 2050, Esab SVI300, MIG 4D wire feeder, Miller Spool Gun 30A, Scotchman Cold saw, band Saw, Belt-Disk sander, Drill Press, grinders, 1966 Kellogg 2 stage air compressor,CK WF-3 cold wire, and a 50 cu. ft. commercial refrig. full of beer! LOl No wonder I can't get anything done!
Pete
Pete
pgk wrote:Miller Passport, Dynasty 300, Spectrum 2050, Esab SVI300, MIG 4D wire feeder, Miller Spool Gun 30A, Scotchman Cold saw, band Saw, Belt-Disk sander, Drill Press, grinders, 1966 Kellogg 2 stage air compressor,CK WF-3 cold wire, and a 50 cu. ft. commercial refrig. full of beer! LOl No wonder I can't get anything done!
Pete
You keep up the beer and I will take the shop and it will all work out. I'll help get your stuff done
Instagram: @farmwelding
Nick
Metalmaster Elite 215 ACDC Tig/stick/plasma. Tokentools 142 Miniarc stick welder.
McPherson 14 inch band saw.
Woodfast 10 inch band saw.
Makita high speed metal cutoff saw.
Makita mitre saw set up for aluminium.
Old manky drill press.
Half a dozen angle grinders.
Half a dozen cordless drills.
Half a dozen motorcycles.
