Is there somewhere I can get a chart that shows the weight limits for rectangular steel tube on the flat side? I need to make a cart for a vertical mill that weighs about 2000 pounds. The mills footprint is roughly 2'-6" wide x 3'-6" deep. I want to use inch and a half by four rectangle tube with a 1/4" wall for the flooring and sides. The flooring would be spaced on 6" centers leaving an inch gap between. The flooring pieces would fit between the side rails on the 2"-6" side and be welded to them. The whole cart will sit on 4 four inch double bearing steel wheel casters.
Is that enough beef for this mill? I would tend to think it's enough, maybe a little too much, but I'd like to hear other opinions on it.
Also, how much bigger should the cart be than the mill. I don't want it to tip over!
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
It sounds like you plan to make a flat-frame out of the tubes. You may have a good reason for wanting to make it that way, but an edge-frame design would be far stiffer and stronger.
Jim ....that's a great reference, thanks. I might have to buy a few ink cartridges and copy it.
Otto... using the wheels as outriggers is a good idea. I'll probably gusset the caster plate to the frame for more strength.
finewoods... the floor will be on the flat side, but the side walls will be upright. I'd normally do the floor upright with the rectangle tube, but that would take up too much height for the mill table this time.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
