Hot ground clamp
Posted: Sun Nov 10, 2019 9:40 pm
by Colby
Hi folks, quick question:
What would make a ground clamp get hot while gmaw welding?
Thanks, Colby
Re: Hot ground clamp
Posted: Sun Nov 10, 2019 9:44 pm
by JayWal
Too small a clamp, poor, dirty contacts and wiring...Mine gets warm when welding over 400 ipm or so. Nothing I can’t comfortably hold bare handed tho.
Posted: Sun Nov 10, 2019 10:48 pm
Welding.
But yea, what Jay Wal said.
Posted: Mon Nov 11, 2019 12:18 am
by tweake
if its just the clamp and not the entire lead, then its simply poor connections. either clamping badly to the work or table etc, or the wire connection. one thing to check is the connection from one side of the clamp to the other. sometimes they break and all the amps go through one side of the clamp.
if the whole cable is hot as well then the whole cable and clamp is undersized.
Posted: Tue Nov 12, 2019 7:58 pm
by Colby
Thanks everyone
Colby
Posted: Sun Nov 17, 2019 10:35 am
by snoeproe
In a weld cable circuit, heat is a form of resistance. Resistance can be from poor cable connections, too small of cables for amperage being ran, poor ground connections etc.
Posted: Mon Nov 18, 2019 12:42 am
by tweake
snoeproe wrote:In a weld cable circuit, heat is a form of resistance..
that doesn't sound quite right.
heat is caused by resistance.
Posted: Mon Nov 18, 2019 5:02 pm
by BillE.Dee
I look at it this way...you're trying to run electrical current thru a cable not big enough or complete the circuit with a poor connection,,something is gonna get hot..now..take your wife's brand new car and it's about 5 1/2 feet wide. Now drive that car thru a bridge that is 5 feet wide. with enough momentum it's gonna go, but your wife is gonna be pretty HOT.
Posted: Tue Nov 19, 2019 10:15 am
tweake wrote:snoeproe wrote:In a weld cable circuit, heat is a form of resistance..
pretty sure that is what was on his mind. But yea, heat/thermal energy is a
byproduct of resistance.
Posted: Tue Nov 19, 2019 3:47 pm
by noddybrian
Yes - but according to the Vogons resistance is futile !
