Good evening. I'm building a house (my own house) and it has a detached garage with an ADU above the garage. Plans call for a wide flange beam to span the width of the garage to support the flooring for the ADU.
The beam is a W12x35 and I already purchased it. On the construction plans it calls for 1/4" stiffener plate to be welded on the end of the beam. It also shows a 3/16" fillet weld on the beam.
My question is: do I weld on web only or web and flange or just flange? The arrow is pointing to the web. Also, should I use dual shield or solid core wire?
Any help is appreciated
Thanks,
Dave
Sounds to me like you need 8 pieces in order to help stiffen the beam. Weld the entire c channel then repeat on the other side and you have four of them down the length of the beam. Divide the beam length by 5 and mark off four divisions.
May I ask wtth is an ADU?
Looks to me like it goes inside the beam, and gets a 3/16 fillet all the way on all 3 edges. IE web and both flanges. The left side of the print calls out 4 pieces on each end. So that’s about the only way it would work out. I would personally just 7018 it.
However you end up welding it, it will probably be strong enough. But will it pass inspection when you or your loved ones go to sell the house many years down the road? Recommend you contact a licensed/certified/qualified construction PM or engineer for your local area to answer your question.
