Cleaning my Machine
Posted: Fri Nov 19, 2021 12:24 pm
by croshaul
I've had my HTP 221 for a few years now and was curious about cleaning under the hood. This never seems to come up in discussion forums
and doing a search brings up nothing.
Re: Cleaning my Machine
Posted: Sat Nov 20, 2021 2:32 pm
by Toggatug
I'll blow my machines out once every couple weeks to a month just through any vents available. I made a longer blow nozzle with a 90 bend to get at the water coolers core through the side vents on the tig machine.
1 time per year the covers get removed and I blow everything off with clean compressed air.
Could probably do the same with yours. Pretty sure my owners/user manuals never said how to remove the covers or maintain the inside though Think I had to ask for the service maintenance manual or whatever they called it to get those details.
Posted: Sat Nov 20, 2021 4:47 pm
It wont hurt. The boards are thick lacquer-coated so they're durable, but the heat sinks are obviously not coated. Take off the carry handle first, then all the torx bolts, lift up about 2" to undo the ground wire female spade connector and away goes the cover. I clean mine about once a year or 1.5 years.
Posted: Sun Nov 21, 2021 1:47 pm
by croshaul
Thanks guys, it's on the to do list.
Posted: Tue Nov 23, 2021 2:19 am
by drizzit1aa
croshaul wrote: ↑Sun Nov 21, 2021 1:47 pm Thanks guys, it's on the to do list.
I don't know anything about HTP's but when a Miller or Lincoln gets too dirty inside (dust, grind dust, humidity), I find I get zapped more often while welding.
