Welding mask and batteries
Posted: Fri Nov 18, 2022 2:04 pm
by Rodbelan
I'd like to know what is the better way to save batteries when the hood is not in use: grind mode? Cause mine has a little flashing light to indicate that I am in grind mode (to avoid being flashed); not sure if it is the right way to store my helmet... Thanks very much.
Re: Welding mask and batteries
Posted: Fri Nov 18, 2022 4:26 pm
by tweake
depends on the model. anything in the manual about it?
one of mine has an off position. the other is auto off.
Posted: Sat Nov 19, 2022 8:12 pm
I hang my welding jacket over it to prevent it from activating (Miller Infinity). Keeps my batteries alive much longer.
During the day if I’m working and off/on with the helmet, I throw it face down for the same reason (sensors are on the front).
Posted: Sat Nov 19, 2022 8:39 pm
by tweake
cj737 wrote: ↑Sat Nov 19, 2022 8:12 pm I hang my welding jacket over it to prevent it from activating (Miller Infinity). Keeps my batteries alive much longer.
where as i have to keep one of mine in the sun as that charges it. if you put them in a box/cupboard for a long time it won't work.
Posted: Mon Nov 21, 2022 8:27 am
by Rodbelan
tweake wrote: ↑Fri Nov 18, 2022 4:26 pm depends on the model. anything in the manual about it?
Noting in the manual about it... It's a Pro Point helmet, made by Jasic, I think...
Posted: Tue Nov 22, 2022 9:36 pm
by Coldman
grinding mode led will drain the battery.
