if you're doing a job with limited space, is it ok to stand your welder on the metal table the earth clamp is connected to?
the welder's a fronius majicwave 2200 set for tig welding
cheers
carl
- winky
Just remember ... rubber melts and burns so standing is better than kneelingOtto Nobedder wrote:No worries. If you're concerned at all, set it on a cheap rubber "welcome" mat.
Steve
... going as fast as I can with one eye closed.
Everlast Powertig 200DX
Miller Thunderbolt 225
Lincoln 180c Mig
Hobart Handler 125
Lincoln 180c Mig
Hobart Handler 125
It's a non issue providing your welder retains it's factory power cord and molded plug, AND your wall outlet and distribution panel is wired properly....INCLUDING proper earth ground rod from panel to earth.
If your welder power cord has been altered, or you doubt your shop wiring is to code, then either research it yourself or hire a qualified electrician to check it out.
MANY folks design and build their welding tables to also hold their welding machines...some on rubber wheeled casters, some not.....It's never an issue if all the above is correct.
Your biggest concern is to protect yourself from providing a path to ground....Always try to clamp machine ground directly to the work piece, and ensure the work piece is cleaned of rust and paint at the ground clamp attachment point, and wear proper shop shoes and gloves-especially when tigging and holding filler rod.
Hobart 210MVP
Hobart 235AC/DC Stickmate
Hypertherm Powermax 45
HF O/A
Longevity Stickweld 140 (intended for Tig)
HF O/A
