ScottiS666
- ScottiS666
Hi guys I have an esab mini arc 90 110 stick welder. I have it retrofitted with a 150 amp tig torch. The power source has a remote plug on it and I was wondering if I can use that to attach a foot petal or a thumb switch so I don't have to use strike arc when I tig? Any help would be greatly appreciated thank you all very much.
Scott, the 90 mini (at least the one we have at work) does not have HF start, so using a remote only gives you amp control. You're still stuck with scratch start.
