Description from Evolution's site:
The EVOSAW185 easily cuts mild steel without heat or burrs and virtually no sparks. The quick-release adjustable vise allows for fast and accurate angle cuts from 0-45˚. Ideal for cutting steel plate, square tube, angle iron, pipe, rebar, copper pipe, conduit, and steel studs.
No Heat, No Burrs & Virtually No Sparks.
No Coolant Required.
Pressed Steel Base.
10A Powerful High Torque Motor.
2 In. x 4 In. Cross Cut Capacity.
2 In. x 2 In. Square Tube Capacity.
2 In. Ø Round Tube Capacity.
Upgrading and would like to sale. Only used 3 times, like new. Comes with two blades; one for non-ferrous metals and one for ferrous metals. These only have a couple of cuts on them. If you've been looking for a chop saw, you know that these are out of stock everywhere and nobody knows when they'll get any more in.
Asking $300
