I've never used a forum before, so I may be a little thick in the head on here.
I'm one step above a beginner welder. Everything I know has been learned the hard way. (Self taught with a lot of welds looking like the back side of a chicken)
I love getting the weekly Welding TV from Jody. Thanks Jody
I would like to know if anyone can tell me how the knobs on my PrecisionTig 275 compare to the settings on the Inverters that Jody uses on his videos. I get totally confused. see attached photo of the welder front panel.
welder front panel.JPG (56.96 KiB) Viewed 2191 times
I've welded miles of aluminum with a PrecisionTig 375 in the past. I may be able to help, and several others here have extensive aluminum experience. I also have extensive stainless experience, though I've rarely used pulse features on it, except outside corners on light-gauge metal.
Thanks!!!
I'm sure I'll need all the help I can get.
I made some brackets for my garden a couple of days ago with some scrap 1" stainless tubing I had laying around. I had to make 2 curved cuts to make it fit together so I could weld it. I kept blowing holes in the metal & couldn't get it to flow very good. Using 3/32 ER308 rod & 1/16 Lanth. electrode with a #5 cup. The settings are what you see on the welder. I had max amps at 110 (just guessed where to set it) using a foot pedal. I'd show a photo of the weld, but don't want to be too embarrassed.
Just as general guidance, when I weld sch. 10 ss pipe (about 1/8" wall thickness), I'm rarely above 65 amps. For sch. 5, about 16 ga. or 1/16", I'm rarely above 45 amps, except at the start to establish the puddle (in either case).
Using a pedal, where you set the machine is just personal preference... The pedal, and your use of it, determines the weld current. Personally, I like to set the machine for the hottest I'd like to limit myself to for the weld, and use the pedal to modulate the current. I know others who prefer to set the machine wide-open, and control everything from the pedal.
I just bought a new TIG machine Everlast EXT 255. I'm having trouble with the WP-20 torch. When I turn on the water it comes out where the gas should be coming out. I hooked up the machine like the manual says. So I don't know if I did something wrong. Sprays water out the cup when you turn on the water pump on. Does anyone have any ideas what I did wrong
You flip flopped a couple of lines. The one hooked to your water outlet is your gas line that's why you have water coming out the cup. Do they use the same size threaded fittings on all three hoses?
Don't remember exactly what video by to know Jody did something similar and had to wash out his lines Ti to make sure to clean the lines for normal welding. I'll try and find it.
on a normal torch the gas goes thru the power line.
For the water-cooled torch you run the water return thru the power line. Gas and cold water thru the two separate smaller hoses, you already figured out which one is gas .
