slacker1965
    Sat Mar 07, 2015 12:24 am
trying to learn about tig-ing 409 ss for a exhaust project.....looked through a lot of videos...looks like I have my work cut out for me...I appreciate the info out here...
    Sat Jul 06, 2013 11:16 am
slacker,
Welcome to the forum.
If you're using 409 in an exhaust you'll need to use ER430 filler and you can also butt weld it without filler if fit up is good. If it's going to tie into any Carbon steel components it will need to be welded with ER309 filler. You'll be better off i you pre-heat it to about 300* F. You'll also get better results if you purge it with Argon, but not 100% required.
Mike
    Mon Dec 06, 2010 1:09 pm
    Andover, Ohio
M J Mauer Andover, Ohio
Linoln A/C 225
Everlast PA 200
    Thu Jan 24, 2013 10:13 pm
    Eddy, TX
slacker1965,
Welcome to the forum! There are several of us that do exhaust work and can help in many ways, others are better suited to help that me though. Post up some pics of what you will be working on when you get the chance.
